1999 dodge durango new motor bad mpg
Old Dec 15, 2010 | 11:32 AM
  #21
SumAmerican's Avatar
SumAmerican
check for fuel leaks around the injectors...
Old Dec 15, 2010 | 01:52 PM
  #22
midnightdurango's Avatar
midnightdurango
i dont smell nothing and i looked already
Old Dec 15, 2010 | 01:53 PM
  #23
midnightdurango
the dealer told being thats its a new engine they might solve it by updating the software
Old Dec 15, 2010 | 10:52 PM
  #24
hydrashocker's Avatar
hydrashocker
And possibly give you the Death Flash!.....Look Out!
What exact Autolite plug did you install?
Old Dec 15, 2010 | 11:08 PM
  #25
midnightdurango
what should i do then the ecm reset didnt make a differnces auto light with like 4 gap i think i dunno
Old Dec 15, 2010 | 11:14 PM
  #26
hydrashocker
Well answering my direct question could help us, however you don't.
Tell ya what, just take it to a dealer and have them fix the whole truck cause you seem to have a lot of issues that you can't seem to fix.
/&out
Old Dec 17, 2010 | 10:12 AM
  #27
midnightdurango
Well the there is also a gas smell in the exhaust like its running rich i don't remember which type of plug i used other then the brand autolites
btw i never changed the cap n rotor would this also cause this or running rich doesnt got to do with anything?
Old Dec 17, 2010 | 10:49 AM
  #28
WhiteWidow00's Avatar
WhiteWidow00
Are you getting an engine code? Did you reset the PCM and are your O2 sensors working?
Old Dec 17, 2010 | 11:59 AM
  #29
SumAmerican
with no check engine light it may be that your plug wires are installed out of order.. seems simple but it will run just fine when 2 of the wires are off.. check and re check this..
Old Dec 17, 2010 | 02:03 PM
  #30
CRAZY MIKE's Avatar
CRAZY MIKE
Default Bad mpg
With all the work thats been done under the hood. Are you sure all vaccume line are hooked up,and or cracked with age. If you have a vaccume leak the ecm could read this as being lean. Demanding a richer mix. Which uses more fuel.
