Power steering issues
Old Dec 16, 2010 | 11:59 AM
cabmkr's Avatar
cabmkr
Default Power steering issues
When I first start out in the morning or after its been sitting for a while the power steering doesnt work initially. After turning the wheel back and forth a few times it starts to work and is fine driving down the road. Its just after i first start out and the colder it is the worse it is. Wondering what i should look for.
2000 Durango, 4.7 4X4
Chris
Old Dec 16, 2010 | 12:37 PM
WhiteWidow00's Avatar
WhiteWidow00
I had this happen to me one time and it could be your rack and pinion getting stuck. Try puting some Lucas Power Steering treatment in it and it should be fine.
Old Dec 16, 2010 | 09:39 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check your power steering fluid level and make sure its topped off
Old Dec 16, 2010 | 10:55 PM
hydrashocker's Avatar
hydrashocker
Maybe time for a fluid change.....Or worn parts.
As Sharps said, I would check the fluid level.
Old Dec 17, 2010 | 07:31 AM
cabmkr's Avatar
cabmkr
Thanks Guys, I am going to do a fluid change with synthetic this weekend and see it that helps.
Old Dec 17, 2010 | 02:09 PM
hydrashocker
Not sure if your takes ATF+4 or Brown Fluid.
I assume that your 2000 Durango takes ATF+4 or red power steering fluid.
If you take Brown Fluid then it is only avalibe at the dealer and is NOT a red type fluid.
To be sure, I would call a Dealer Service Center and give them your VIN#.
