1st generation offtopic thread
Old Aug 16, 2010 | 12:12 PM
  #61
4wheelin's Avatar
4wheelin
No doubt SadikOne! I actually live in Winder so you are very close. I'll send ya a PM soon!! Later !! Go Dawgs!!
Old Aug 16, 2010 | 12:16 PM
  #62
4wheelin's Avatar
4wheelin
Originally Posted by acehole420
Hey everyone... I just bought my durango not to long ago and its goin in the shope for a 3 inch body and the t/b lift.. Whats the biggest tire i can fit? Ill get some pics up of it soon..
You can run 33x 12.50's all day long with the body lift, I do. I have a little scrubbage on full steering lock but its just on the black plastic in the fender well. No biggy. Good Luck!!
Old Aug 16, 2010 | 07:29 PM
  #63
acehole420's Avatar
acehole420
Heres my D for now... Next week Imputtin the 3" body lift as well as the torsion bar lift... Gonna go with 33 x 12.50s... But until then this is what she is
Old Aug 20, 2010 | 11:19 PM
  #64
kingoftow's Avatar
kingoftow
Default towing my D...
Hey shrpshtr325, I want to be able to tow my 1998 Durango behind my motorhome with all four wheels on the ground. Can I just put the transfer case in neutral, unlock the steering and pull it down the road with either my 5000lb. Valley or my 7,500lb. Blue Ox tow bar? Also do you know of any tow tab kits available or should I break out my Mig welder and fab up a bolt on setup...kingoftow
Old Aug 20, 2010 | 11:39 PM
  #65
kingoftow's Avatar
kingoftow
Default same setup's...
magic84...howdy, it's like we called each other, I too installed a Kenwood sterio / duralast gold battery and a bosch water pump...nice 'Rango you have there...kingoftow
Old Aug 21, 2010 | 07:36 AM
  #66
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
kingoftow, please start a new thread about that, and i will be more than happy to answer your questions
Old Aug 21, 2010 | 08:34 AM
  #67
acehole420's Avatar
acehole420
Thanx man i apreciate it... Well everything should be done by friday Im hopin... So hopefully this weekend ill Get some pics up Ne suggestion on tires...I really dont wanna go all terain but most mud tires are real soft and die quick on the road...
Old Aug 23, 2010 | 09:58 AM
  #68
kingoftow's Avatar
kingoftow
Default ...towing my Durango...
Yeah, from what I can gather, there are several brush guards available for our Durango's. I'm wondering if maybe I can incorporate some brush guard brackets (probably have to beef them up with some creative welding), but at least that would give me some starting mounting points. shrpshtr325, do you know who might make the strongest mounts?...kingoftow
Old Aug 23, 2010 | 10:13 AM
  #69
kingoftow's Avatar
kingoftow
Default ...roof rack...
Hey sadikone1, looks like you had a good time, say about your roof rack...did you mount that directly to your factory cross bars? I attach a Thule roof top pod to the bars on my '98 Durango SLT 'loredda'. I try not to load it heavier than the owners manual says(150 lbs). Did you have to reinforce your rack mounts?...kingoftow
Old Aug 24, 2010 | 01:41 PM
  #70
SadikOne1's Avatar
SadikOne1
Hey,
No I didn't have to use my factory bars. I threw those out because they were broken. The rack you see is from SURCO and it came with all the hardware necessary. As far as weight goes, Yea it's safe to keep it under that but i think with this new rack the weight max should be 200-250. Not too sure though.
check surco out on ebay, they got great stuff in different sizes!
