Unknown Noise. Need Help!
Old Dec 21, 2010 | 03:40 AM
91BWilson's Avatar
91BWilson
Default Unknown Noise. Need Help!
I have an '03 Durango. I did a tune up on my truck and right after it started to make a ticking noise under the hood. I can hear it in the cab and sometimes it vibrates real bad but it only does it when it's in gear even when I'm sitting still in gear. What's the deal.
Old Dec 21, 2010 | 07:26 AM
WhiteWidow00's Avatar
WhiteWidow00
Like I asked in your first post, what kind of plugs did you use and were they properly gapped to .040?
Old Dec 21, 2010 | 09:20 PM
91BWilson's Avatar
91BWilson
I'm not sure but I think they were champion plugs but yes they were gapped properly
Old Dec 21, 2010 | 11:06 PM
WhiteWidow00
Is there anything erratic showinnon your tach when it is doing this? And were they just the cheap champion copper plugs? As long as they had nothing to do with platinum.
Old Dec 22, 2010 | 02:23 AM
Biff85ta's Avatar
Biff85ta
It is not the plugs most likely. I would try the wires first either one is not seated well or moving an old wire has exposed cracks or bad spots in the insulation and it is sparking to ground which would explain the rough running and the tick. The easy way to find this kind of problem is to go out in the dark and fire it up and you should be able to see the spark.
Old Dec 22, 2010 | 01:22 PM
Bobman's Avatar
Bobman
Not sure about the other engines available, but the '03 4.7's have individual coil packs on each plug with only 12v going to each one, as well as they bolt down onto the plugs so it's pretty tough to install them wrong. They will break if rough handle them when they're removed, and it will cause the same symptoms. I think the CEL will code out to a misfire though. In my case I *knew* which one I dropped and swapped it when the truck missed on startup. Make sure you didn't damage a connector when you removed them from the coil pack (the locks are tough to disengage sometimes).
Bob
Old Dec 22, 2010 | 01:33 PM
Biff85ta's Avatar
Biff85ta
The 318 and 360 have a standard distibutor and wire setup. The OP did not mention it in this post and did not even think about the 4.7 as mine is a 360.
Old Dec 22, 2010 | 05:23 PM
hydrashocker's Avatar
hydrashocker
If the sparks are colder or of other than OEM it makes the motor tick. Replace them with the correct plug Champion Copper and gap at .040.
It sounds like under load is the tick, well try a better fuel or octane as this could be ping.
Then again:
Most likely it's what you replaced! Um, maybe it could be the spark plugs.....LOL....It's the only other thing it could be on a 4.7L cause it's the only thing you changed.
Old Dec 22, 2010 | 09:36 PM
WhiteWidow00
LOL thank you hydra for giving a reason why I was asking about the plugs.
Lets try this again? Were they the cheap champion spark plugs? As long as they were not platinum. Iridium is fine.
Old Dec 22, 2010 | 11:56 PM
hydrashocker
No problem Widow.....LOL
