Timing chain cover
Old Dec 28, 2010 | 09:01 PM
Rcruz's Avatar
Rcruz
Default Timing chain cover
New to site and need to remove timing chain cover to repair water leak between cover and block. Can this be done without removing oil pan and have there been a problem with coving warping?
Does anyone have a picture of special tool to remove clutch fan?
Thanks
Old Dec 28, 2010 | 11:02 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
need more information man, which engine are we working on? 5.2, 5.9, 4.7? also what year would help
Old Dec 29, 2010 | 12:01 AM
IndyDurango's Avatar
IndyDurango
Generally, it is the water pump. Very few (like zero) reports of a leaking timing chain cover.
Just saying.
IndyDurango
Old Dec 29, 2010 | 12:24 AM
samnbensdad's Avatar
samnbensdad
When I bought my used 02, 5.9L, it appeared to have a leak around the timing chain cover. It was actually coming from the thermostat housing, directly above. The previous owner damaged the surface that seats the thermostat (probably from using a wire brush to remove RTV/gasket on the aluminum surface), so coolant was slowly leaking through. The silicone based RTV was sufficient to fixed the problem.
Old Dec 29, 2010 | 02:08 PM
hydrashocker's Avatar
hydrashocker
Thanks for the update!
Old Dec 29, 2010 | 04:37 PM
samnbensdad
Do I have to be the one to make the alcohol reference this time?
Old Dec 29, 2010 | 04:39 PM
Rcruz's Avatar
Rcruz
Sorry, its a 1993 with 5.9 in it. I could see the leak from the timing cover right top corner. I'm getting ready to remove the homonic balancer but different set up from GM. No threads on balancer to run puller to remove. It there a trick to removing?
Thanks
Old Dec 29, 2010 | 08:15 PM
samnbensdad
1993???
Old Dec 29, 2010 | 09:38 PM
shrpshtr325
THE ULTI-MOD
probably 2003, but im not sure, the OP will have to clarify since these trucks were only made btwn 1998 and 2003
Old Dec 29, 2010 | 10:33 PM
Rcruz's Avatar
Rcruz
TYPO error its a 2003
