Starting Issue
Old Jan 5, 2011 | 05:55 PM
reachinOUT's Avatar
reachinOUT
Default Starting Issue
I just went to crank my D and it turned over and started for a second and then dies. When it starts, the rpms jump for a second or to and then lowers and dies. I can keep it running by keeping the gas pedal pressed. If I let it off it falls on its face. After doing this a few times it finally stays cranked. After idling for awhile I shut it down and tried to crank it again. It cranks fine but when the rpms settle after cranking the engine it drops down to 400 and acts like it wants to die and goes back to 600 rpm and everything is fine. When the rpms drop to 400 my lights flicker before it goes back to 600 rpms. Does anybody have any suggestions on troubleshooting this problem. I love my 2000 Durango 4.7, it has almost 200k on the speedo and never any problems other than ones that I have caused.
Old Jan 5, 2011 | 05:59 PM
1999_Durango_SLT's Avatar
1999_Durango_SLT
Bad Battery maybe? This happen to me and it was my Alternater and Battery.
Old Jan 5, 2011 | 06:09 PM
reachinOUT's Avatar
reachinOUT
The battery is a 1.5 year old optima yellow top. I doubt the bat is the culprit, but the alternator is a good candidate being that I have never replaced it. I will have to ask my father in law about it being that he is who I got it from.
Old Jan 5, 2011 | 06:14 PM
WhiteWidow00's Avatar
WhiteWidow00
I would say your IAC is stuck. I'd start by replacing this. It's only $40 from autozone and a cheap place to start.
1999_Durango_SLT
If you have a volt meter tester you can test both at home. If it is the Alternator it could break down the battery a lot quicker too.
Old Jan 5, 2011 | 06:16 PM
reachinOUT's Avatar
reachinOUT
Is there any way to troubleshoot the IAC?
Old Jan 5, 2011 | 06:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i agree with whitewidow, sounds like the IAC motor, nope, no way to troubleshoot it that i know of, however it is a classic symptom for the truck to only start w/ the gas pedal floored when this goes bad or needs cleaning (you could try cleaning it before you replace it, this sometimes works, but is not a certainty)
Old Jan 5, 2011 | 06:41 PM
WhiteWidow00
There really isn't but what I can provide you with is some useful things (cleaning out the IAC and throttle body).
https://dodgeforum.com/forum/1st-gen...ttle-body.html (for if you have a 5.2/5.9)
http://www.mediafire.com/?k0742k5tvj1dqxh (for if you have a 4.7)
BTW, in the future it helps us out to know what engine you have. Just put it in your sig or in the post. Different engines have different symptoms.
Old Jan 5, 2011 | 06:50 PM
reachinOUT's Avatar
reachinOUT
Thanks, I certainly will try cleaning it and report back.
Old Jan 6, 2011 | 03:54 PM
reachinOUT's Avatar
reachinOUT
Thanks fella's for the advice. It looks like it was the IAC. I cleaned it and installed it back and walla it was back to its old self again. It would start up and ramp the rpms to 1500 for a sec and ease down to 1000 for another sec then drop down to 650 for idling. The symptoms are gone and all is good on the home front. It even went back to bumping the idle up a tick to compensate for an accessory being turned on.
If there was a thanks button I would press it since there is not I will give you some
