HELP! O2 Sensor Issue
Old Jan 5, 2011 | 07:07 PM
R-TICAT's Avatar
R-TICAT
Default HELP! O2 Sensor Issue
Have a 2001 Durango 2wd with a 4.7 and 160,000 miles.
Original O2 sensors lasted 155,000+ miles.
Been through 6 since (5 up-stream and 1 down-stream) in the last 2 months. They seem to last about 2 weeks +/-.
No sign of external contamination that I can find.
Haven't done any engine work so, no possible contamination from silicone sealers.
Thought maybe a leaking headgasket and hence, possibly antifreeze contamination but, no change in coolant level.
I heard the after market ones were junk so, spent the $100 on the Mopar one and it lasted a shorter time than the Bosch ones from Autozone.
Any help would be appreciated!
Old Jan 5, 2011 | 07:27 PM
harleytech's Avatar
harleytech
What codes are you getting ?
Old Jan 5, 2011 | 07:35 PM
R-TICAT's Avatar
R-TICAT
Default Codes
P0171 is the code every time the up-stream sensor goes. Last time, also got a code for the up-stream sensor heating circuit slow to respond. I can't remember what the # was, P0133 maybe?
Old Jan 5, 2011 | 09:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have a power steering switch leaking at the P/S pump hose's?
Old Jan 6, 2011 | 05:40 AM
R-TICAT's Avatar
R-TICAT
I haven't seen a leak...where exactly is this switch located?
Old Jan 6, 2011 | 10:14 PM
hydrashocker's Avatar
hydrashocker
On the pressure line.
Old Jan 7, 2011 | 10:33 AM
R-TICAT's Avatar
R-TICAT
OK, no outward sign of a leak but, I unplugged the wire from the switch and it is all "wet" inside with oil (fluid)!
Old Jan 7, 2011 | 11:17 PM
R-TICAT's Avatar
R-TICAT
Changed the power steering pressure switch and cleaned the plug with CRC Electrical Cleaner, then blew it out with air...repeated 3 times.
Hope this cures the O2 sensor issue...is there something else I should do?
Old Jan 7, 2011 | 11:42 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
keep an eye on it for a month or so to make sure there is no more fluid loss, and no codes thrown but other than that you should be done
Old Jan 8, 2011 | 12:37 PM
Bobman's Avatar
Bobman
OK, you lost me on this one.... where's the connection between the PS pressure switch and O2 sensor codes?
Bob
