fuel pump?
Old Jan 10, 2011 | 11:53 AM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea i agree w/ indy, 160 is too cold, 180 is as cold as i would go and 195 is stock
Old Jan 10, 2011 | 01:50 PM
  #22
hydrashocker's Avatar
hydrashocker
+1.......160 is too cold, 180 or 195, but 180 is best for the 5.2L and 5.9L as the heads like to crack between the intake and exhaust valves because of the 195 constant heat.
Old Jan 10, 2011 | 05:34 PM
  #23
durango12's Avatar
durango12
Thanks guys you are life savers! Now that i think about it when i put that in shortly there after it started doin it! I will change the stat by this weekend and get back with you. Also on spark plugs i run the autolite iridiums with 93 pctane and i dont have any spark knock i love them.
Old Jan 10, 2011 | 07:35 PM
  #24
hydrashocker
I would not run Autolite Iridium, but each to their own.
Old Jan 12, 2011 | 01:22 AM
  #25
durango12's Avatar
durango12
Perfect! After puttin in 180 stat and reset the pcm. No more detonation at high rpm and it gets better mpg thanks for your help
Old Jan 12, 2011 | 02:19 AM
  #26
IndyDurango's Avatar
IndyDurango
Tada!
