2002 Durango R/T Intermittant running problem
Old Jan 17, 2011 | 05:51 PM
ziggy's Avatar
ziggy
Default 2002 Durango R/T Intermittant running problem
Happens very intermittently. Motor feels like it starts to shake a little, and even if I add more gas by stepping on the pedal a little, it is not speeding up. It just crawls along. It feels like it is about to die, but it will not die. Usually I have to pull over and give it a bit of gas until it smooths out. Worried this will happen in a busy intersection when I need some power! I took it to the dealer, they had it for two days, and claimed it did not do this while they were driving it. Ran some injector cleaner in it with the last two fill ups, and that did not help.
Help!
Fuel pump going out? Catalytic converter?
5.9L V-8 2002 Durango R/T.
Old Jan 17, 2011 | 07:03 PM
WhiteWidow00's Avatar
WhiteWidow00
Check the pre CAT exhaust for back pressure. It should not be more than 2-4 psi, and if its more then you have a likely blockage in your CAT and needs replaced.
I am also having this problem however have not found a cure yet.
I would also check over your O2 sensor wiring under the truck especially by the transmission and ensure there are no open wires or any shorts in the wiring.
Old Jan 17, 2011 | 07:13 PM
ziggy's Avatar
ziggy
Thanks for the reply. Will try those things. Anything else anyone can think of I should look into.
Old Jan 17, 2011 | 08:28 PM
IndyDurango's Avatar
IndyDurango
You have a dying battery. Have it tested under load.
Low idle stumble is almost always battery related.
Old Jan 17, 2011 | 10:21 PM
ziggy's Avatar
ziggy
Would I be seeing any other symptoms? Just curious, as it starts fine, and the volt gauge always sits right in the middle. Can a dying battery just produce the symptoms the low idle stumble you mentioned without anything else?
Thanks for your reply!
Old Jan 17, 2011 | 10:43 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
simple answer, yes
it is also known to cause the trucks to die w/ no warning(at idle) and all sorts of weird little things.
Old Jan 18, 2011 | 01:27 PM
hydrashocker's Avatar
hydrashocker
Have you cleaned the TB and IAC and reset the PCM?
Old Jan 18, 2011 | 03:34 PM
LuxuryDodge's Avatar
LuxuryDodge
Im sorry to go off topic, but could someone tell me exactly (with pics would be AWESOME) on how to remove/clean/reinstall the IAC? I saw the sticky on it but it just wasnt to clear to me, and I just REALLY do NOT want to fonk up this truck, and so I dont **** off any mod's or other's, just message me, thank you!
Old Jan 18, 2011 | 09:04 PM
IndyDurango
Yes we can.
Start a new thread however.
