Air/Fuel Mixture thrown off
Have you tried pulling reflashing your PCM back to stock? I.E. Pulling out the tune from your handheld? I would also definately check the powersteering switch. It seems to cause all kinds of isssues. I also know that when my PCM failed on my 2000 Sebring it acted similiar to what you describe from your but when connected to a scan tool you could get next to nothing as far as data from it.
Another thing you might try if none of this is any help is pull the fuel rail and have someone cycle the key if possible to check for a leaky injectors. I doubt but I have seen an instance on a friend car where one actually stuck open. We had fun with it as the car was beat and a newspaper and a lighter meant he had flamethrowers.
P.S. Just a gut feeling here and could be totally wrong but I think you may be the victim of timing chain stretch. I have seen similiar problems in the past and have even seen a mani or two glow red from the excess exhaust heat.
Last edited by Biff85ta; Jan 24, 2011 at 02:19 AM. Reason: Needed to add something
Another thing you may want to check is the IAT sensor in the front passenger side of the intake manifold. If it's faulty and causing it to read a very low incoming air temp, the PCM will literally dump fuel into the system. Just something to think about.
I forget what it's called, but have you tested the air intake sensor? On a GM vehicle it would be a mass airflow sensor, but chrysler uses a sensor that checks pressure instead of flow. Either way they're providing the same data to the computer. I'm sure somebody will chime in with the correct name for the sensor I'm thinking of...
If the computer is getting bad info about the amount of air entering the engine, that could easily cause it to set the mixture too rich.
Also what about a pre CAT 02 sensor not warming to temp but not low enough to trigger a code.
Also a MAP or intake manifold air temp sensor.
