Battery suggestions
Old Feb 9, 2011 | 11:56 PM
  #31
Groggy's Avatar
Groggy
Thank you WhiteWidow, that is a good reference diagram for trailer wiring, but how 'bout for the D. I'm a little worried (now) that the wiring on the D has been modified, or damaged. I want to protect the trailer and don't want anything avoidable to happen to my D either.
Old Feb 10, 2011 | 10:56 AM
  #32
WhiteWidow00's Avatar
WhiteWidow00
Look at before the trailer connector on the diagram, it gives you colors and they should match up according to code. The colors are pretty universal and if I'm correct, they should match up color wise to your factory pole.
Old Feb 10, 2011 | 01:42 PM
  #33
Groggy's Avatar
Groggy
Thanks for the help WW I was hoping to find a factory wiring diagram of my D to find out how the power supply is "supposed" to be connected, So I can determine if something is wrong with the way that mine is. That was the Schematic I was really after, but I printed out the plug/trailer diagram that you posted and put a copy in my TT in-case I have to fix something in the woods!
Old Feb 10, 2011 | 06:30 PM
  #34
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check the FAQ at the top of the page, one of the service manuals linked to in there should have the wiring diagram you are looking for
Old Feb 20, 2011 | 11:25 AM
  #35
Groggy's Avatar
Groggy
Default Got It!
So I managed to Download the 2000 Service Manual, only to discover that the 8W (Wiring) and 21 (Transmission and Transfer Case) files are missing... If anyone has these sections I would love to have a matched set. Anyway, I then Downloaded the 2002 Service Manual (which is complete). Based on 8W-10-14, 8W-54-2 & 8W-54-3 there is no relay or connection to the Ignition Switch in the factory wiring. Just a direct run from the Trailer Tow Connector to the Battery through the Power Distribution Center and Fuse C for a 20A Fuse. At least now I know that what I have going on (Based on the 2002 Wiring Diagram) is that way from the factory.
Old Feb 20, 2011 | 12:47 PM
  #36
shrpshtr325
THE ULTI-MOD
8w http://www.mediafire.com/?mzxfxtynn1d
21 http://www.mediafire.com/?2tjnmmmmtjw
its all in the folder linked to in the FAQ thread
Old Feb 20, 2011 | 09:29 PM
  #37
Groggy's Avatar
Groggy
Oh wow, Thank you! I went back and realized that I am in fact a doofus! I only now (since I followed the links you provided) realized that my Dumb A#@ didn't switch to the second page of files to find the 8W file... So Thank you, and Sorry!
Old Feb 20, 2011 | 10:11 PM
  #38
shrpshtr325
THE ULTI-MOD
and there is also a third page if you are really interested
