Oil pressure gauge is high
Old Jan 29, 2011 | 05:47 PM
M Shark's Avatar
M Shark
Default Oil pressure gauge is high
Yesterday I noticed my oil pressure gauge on the high side. Are there any concerns about this? I checked the oil level and leaks and everything looked ok. I'm just concerned about anything that might be going bad.
Old Jan 29, 2011 | 06:51 PM
Biff85ta's Avatar
Biff85ta
Nothing I would worry about.
Old Jan 29, 2011 | 07:55 PM
coreybv's Avatar
coreybv
I'm guessing it was pretty cold out?
Old Jan 29, 2011 | 08:02 PM
WhiteWidow00's Avatar
WhiteWidow00
Typically on a cold start the oil pressure is higher than normal before the engine heats up. How long ago was your last oil change? Typically a clogged filter can give you a higher oil pressure, at least if that's your oil pressure when its heated up at idle.
If it's like that after a cold start, don't worry about it.
Old Jan 29, 2011 | 08:04 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
as said above, if thats the cold start pressure its fine, especially with the cold temperatures we have been having lately
Old Jan 29, 2011 | 08:26 PM
01 6.3L RT's Avatar
01 6.3L RT
I agree with all that is said . i`ll add if you ever have to change yur oil-pump don`t go with stock , get a aftermarket ( Melling) hi-flow pump ,,, (not hi-pressure ) ,,, more oil flow is better than higher pressure .And Melling has one that give you 25% more flow ,,,,,
Old Jan 29, 2011 | 10:04 PM
hydrashocker's Avatar
hydrashocker
The person who did your oil change could have used 10W-40 instead of 10W-30 and that would do that to your pressure. Keep an eye on it and after about 500-800 miles it turns black/dirty then that is most likely your issue.
I had a guy do that before.
Old Jan 29, 2011 | 11:54 PM
M Shark's Avatar
M Shark
Thanks for the reply guys. I probably do an oil change on my next day off. The pressure gauge is like that all day even after driving the truck around town. And I live in south Texas where temps are around 60-70's.
Old Jan 30, 2011 | 01:19 AM
WhiteWidow00
That's what I would do, and use a quality filter (Mobil1 or Bosch) and a quality 10W-30 oil such as Mobil. If you're looking for consistency in your oil and extreme quality, hydra and I suggest Mobil 1 as I have used it since I bought my truck and have yet to have a problem oil related.
Be sure to spend a few extra bucks this oil change and put a good oil and filter on it though, this should help it.
I'd also replace the PCV valve because a clogged valve can cause all sorts of oil pressure problems and its cheap/easy enough to replace, just to rule that out as a culprit.
Old Jan 30, 2011 | 04:29 AM
topdogcustoms's Avatar
topdogcustoms
thats where mine runs at all the time i dont know what they were running for oil before but i switched it to mobil 1 10-30 and a mopar filter
