Question
Old Feb 11, 2011 | 02:38 PM
coreybv's Avatar
coreybv
Originally Posted by gasseous
I have a squeal when it is cold outside. (It goes away when the engine warms up) I have thought that this was the A/C clutch but who knows.
First thing to check is your serpentine belt and tensioner.
Old Feb 11, 2011 | 02:57 PM
WhiteWidow00's Avatar
WhiteWidow00
Yep, 9/10 times if it only does it when it's cold out it's just a belt tension pulley. Spray some WD-40 on it and see if it's still there.
Old Feb 14, 2011 | 09:23 AM
Dans01Durango's Avatar
Dans01Durango
Wouldn't the oil corrode the rubber? I've used brake fluid before because that didn't break down the rubber compound.
Old Feb 14, 2011 | 09:54 AM
Biff85ta's Avatar
Biff85ta
Originally Posted by bigred_84
Thanks for the fast response everyone. It was the belt I replaced it and it went any. I have another question though. I just bought this truck it has the factory radio in it and the infinity system. The guy said he bought it from a friend and he had a custom system in it and took it out when he sold it but didn't put the amp back in so now the sound doesn't work. Is there any way around this or do I need the amp. Thanks
Pull the radio out and see if there is a black wire that is not connected. Most people will cut the end off of it and it is a ground fro the factory amp. Put a female blade connector on it and connect it to the tabs on the back of the radio.
Old Feb 14, 2011 | 10:43 PM
hydrashocker's Avatar
hydrashocker
WD-40 is not an oil, it is more of a cleaner than anything. It also acts like a water dispersant. That's why you could take off a distributor cap that has water in it and spray out the moister with WD-40 and wipe with a rag and place it back on without an issue (old back yard trick). WD-40 will evaporate as well and leave a useless chalk.
Old Feb 14, 2011 | 10:52 PM
WhiteWidow00
Actually, a bit of useless information but WD-40 stands for "Water Displacement, 40th Attempt".
Old Feb 14, 2011 | 11:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
damn it widow, i was gonna post that
Old Feb 15, 2011 | 10:49 AM
Dans01Durango
I stand corrected! Use the WD-40!
Old Feb 15, 2011 | 11:05 AM
coreybv's Avatar
coreybv
Just don't rule out the tensioner if the WD-40 doesn't work. When I had my water pump done the tensioner was frozen up bad enough that the mechanic had to cut the belt to get it off, even after trying to lubricate it and force it to move.
Also, even if the tensioner is good, those belts get a bit of a "glaze" on them over time and can start slipping. Once they get that glaze on them, they're slippery, especially when cold.
Old Feb 15, 2011 | 11:09 AM
Dans01Durango
Another good point made by Corey.
