alternator pulley
Old Feb 18, 2011 | 12:45 PM
01 6.3L RT's Avatar
01 6.3L RT
Why not put a set of underdrive pulleys from March Performance Pulleys,,,i have a set on mine motor ,,,they do free up about 12.5-15hp typical at rear wheels ....not a myth is does free that much up from less accessory drag
Old Feb 18, 2011 | 03:09 PM
coreybv's Avatar
coreybv
Are you absolutely sure it's the alternator pulley? This seems like an awful lot of work if you're just guessing.
Could very easily just be due for a new serpentine belt... As they age the rubber gets hard and "less sticky", causing them to slip a little and squeal.
Old Feb 18, 2011 | 04:52 PM
samnbensdad's Avatar
samnbensdad
That's where I was going with my questions too.
Old Feb 18, 2011 | 05:31 PM
jmess's Avatar
jmess
like i said. it goes way for a little while when i spray that particular pulley with pb blaster
Old Feb 19, 2011 | 01:21 AM
hydrashocker's Avatar
hydrashocker
Lmfao...........Ewwwwww
Guessing there is your problem..........
Anyway, if you use a lubricant/cleaner and the problem goes away the most likely that is your issue.
Old Feb 19, 2011 | 12:12 PM
samnbensdad
Replacements are hard to find. But I found this MSD universal replacement. It looks pretty awesome if you're willing to drop $40+ on one. http://www.streetsideauto.com/p/msd-...ampaign=Pronto
The MSD site has more specific details about it: http://www.msdignition.com/Products/...tine_Belt.aspx
Old Feb 19, 2011 | 12:39 PM
WhiteWidow00's Avatar
WhiteWidow00
I'd check at RockAuto or NAPA for a replacement pulley.
Old Feb 23, 2011 | 03:45 PM
coreybv's Avatar
coreybv
Right, but a lot of those lubricating sprays will temporarily soften rubber. So if a little bit of overspray got onto your belt it could make it a little more sticky for a little while and eliminate the squeal.
Not saying your diagnosis is wrong, just suggesting an easier option to try first. Especially since it's a good idea to keep those serpentine belts fresh anyway.
