alternator pulley
so the pulley on my alternator is extremely squeaky, annoying as hell. the local parts store doesnt have one and cant order it and i cant find one online either. so my question is can i buy just the pulley or do i need a whole new alternator?
i know its not the tensioner pulley. i thought it was that at first and replaced it and the squeal was still there. i tried listening with a tube but all i can hear is wind from the fan. i do know that is coming from the passenger side though. and also if i spray the pulley on the alternator with some pb blaster the squeal stops for about 30 seconds
They're a huge PITA to install and when is easiest to do is take the belt off and remove the cables going to it of course, and take an air wrench with the size bit on it and undo it on top speed.
If you don't have an air wrench, you must lock up the pulley and then go thru the process of undoing the bolt.
no. the fan just blows it everywhere when i do and i dont have a straw for it. i did it multiple times. id start thre truck, it would squeak. id turn it off and spray it, it wouldnt for about 30 seconds. and then id do it again without spraying, then spraying, ect.
They're a huge PITA to install and when is easiest to do is take the belt off and remove the cables going to it of course, and take annals wrench with the size bit on it and undo it on top speed.
