HD Radio in 2000 Durango
Old Feb 18, 2011 | 08:05 AM
docmatt's Avatar
docmatt
Smile HD Radio in 2000 Durango
Hi all,
I read the thread on removing a stereo from a 2000 Durango, but I got a bit confused as the thread went (the people there clearly had more knowledge about different gens of Durango than I do, etc.). So I want to be clear before I rip out the stereo.. ;-)
Ok, so here is the thread: https://dodgeforum.com/forum/1st-gen...o-removal.html
So, do I just pull out something that is directly around the stereo to access the bolts, or do I have to take the whole panel off? Either way, do I need any special tools to do this? Do I need to unplug the battery before taking wires off?
Old Feb 18, 2011 | 11:01 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if your dash looks like this you need to pull a large portion of it off in order to get the radio out
however if your dash is different, then there should be a bezel which just pops off that you need to remove
Old Feb 18, 2011 | 02:06 PM
hydrashocker's Avatar
hydrashocker
Well I'm still lookin for a square OEM head unit.
I found a rounder version just like yours Sharps but I don't think their interchangeable?
Old Feb 18, 2011 | 02:31 PM
shrpshtr325
THE ULTI-MOD
nope afaik they arent, i think we tried btwn my dads 03 dak and my old 98
Old Feb 18, 2011 | 02:52 PM
hydrashocker
TY
That's why I didn't buy it. I was about 99% sure it wouldn't work.
Old Feb 19, 2011 | 08:41 AM
docmatt's Avatar
docmatt
Default Pics
Hey, attached are some pictures of my stereo and dash, just to make sure we are on the same page. What is the procedure with this layout? Thanks so much!
Attached Thumbnails HD Radio in 2000 Durango-picture0003.jpg   HD Radio in 2000 Durango-picture0004.jpg   HD Radio in 2000 Durango-picture0005.jpg
Old Feb 19, 2011 | 10:56 AM
WhiteWidow00's Avatar
WhiteWidow00
Ok doc you have my setup, first you'll have to get a regular butter knife and stick it in the bottom right (passenger side) corner and you'll feel a little tab. Press that in the the fascia piece should start coming undone. I recommend pushing in the parking brake, putting the gear shifter in the lowest gear, and tilting the steering wheel full down.
Once the fascia cover is off it's smooth sailing from there. There's 2 bolts on the radio keeping it in and once you remove those (I believe 1/2" socket) you can slide the radio out.
Very easy install compared to other vehicles I've worked on IMO. Be careful taking out the fascia cover that you don't break the tabs.
When replacing the fascia cover just put it back in place the pop it back on, very easy!
Oh, and FYI its much easier in the future when asking questions regarding the dash components, that you state it's between 1998-2000.
Old Feb 19, 2011 | 01:26 PM
shrpshtr325
THE ULTI-MOD
yup he hit that on the head, the wood grain bezel piece should just pull off and then the radio unbolts, just as widow said
Old Feb 19, 2011 | 04:51 PM
WhiteWidow00
Be sure to PM hydrashocker. Not sure what you're planning on doing with the old radio if you're replacing it, but that's the radio hydra is looking for so I'm sure if you were wanting to sell it, he'd buy it! That's the nice radio with the CD player and equalizer!
Old Feb 20, 2011 | 02:41 PM
docmatt's Avatar
docmatt
Default Thanks!
Thanks so much all! The install went very swimmingly. I even pulled off the panel below it (unscrewing it) so that I could run some wires from the back of the radio to the HD radio unit; it worked out well. Thanks again for the advice and instructions ;-)
