ODB II not working
Old Feb 28, 2011 | 07:34 PM
davydfarrell's Avatar
davydfarrell
Default ODB II not working
Can anyone help??
I went to take my 2000 Durango in to get smogged.
and i guess the ODB plug isn't communicating with any of their readers.
Im hoping it's just a fuse, manually checked them all, they look fine... but i could be missing one.
and so which fuse is it???
thanks so much, need to get it smogged asap
and this data connector problem isnt helping
wont send any codes or read it all all
quik response would be great
=D
Old Feb 28, 2011 | 08:14 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
did you check all the fuses in the panel in the door jam? on the 'secret' hidden fuse panel behind the one in the door jam? and did you check the ones in the PDC under the hood.
Old Mar 1, 2011 | 12:26 AM
hydrashocker's Avatar
hydrashocker
Try a different shop.
Old Mar 1, 2011 | 12:34 AM
davydfarrell
ya, i checked the side door panel fuses
thought it would have been the cigar fuse, changed it with a spare, wasnt it
also checked under the hood main fuse box...none looked blown
but i also could be wrong, so help with what fuse is shared with the ODB II plug would be awesome, so i could just replace it and cross my fingers that was it.
btw is there any other fuse box other than the one under the hood and the drivers door jam???
Old Mar 1, 2011 | 09:28 AM
Dans01Durango's Avatar
Dans01Durango
Yeah, there's a "hidden" one BEHIND the door jamb fuse box. You have to get on your back and look up where the ebrake's area is. You'll see the fuse box shrps is talking about.
Old Mar 1, 2011 | 11:37 AM
davydfarrell
oh ya, where i replaced the turn signal relay
/slaps head
Ill give it a look today, and will reply if that fixed it
thanks
Old Mar 1, 2011 | 02:26 PM
davydfarrell
nope, wasnt any of those fuses either...
damn
any other suggestions guys???
Old Mar 1, 2011 | 02:40 PM
WhiteWidow00's Avatar
WhiteWidow00
Maybe a bad ground or PCM. Try resetting the PCM and checking the wire leads. It sounds to me like something from the port got pulled loose and it's not supplying power if the fuse is in tact. I'd check the routes for all your wires coming from the OBD port and trace the problem down.
Possibly a bad ground.
