low power
Old Mar 1, 2011 | 06:47 PM
  #21
Mastec's Avatar
Mastec
Walmart sells Seafoam if you have one near you
Old Mar 1, 2011 | 09:35 PM
  #22
jmess's Avatar
jmess
i went there right after auto zone and they didnt have any either. oh well. i find some tomorrow
Old Mar 1, 2011 | 11:35 PM
  #23
hydrashocker's Avatar
hydrashocker
Heat isn't bad, but all it should be used for is if water is in the fuel and you don't use it unless. Seafoam is a pretty good cleaner.
Anytime you park a motor you should get some fresh gas and mix fuel stabilizer in it to keep the fuel fresh so it doesn't varnish. Get the sh!ty gas out of it and put some new 91 octane fuel in even if it's only 5 gallons. Check the exhaust pipes for any real hot sections that would represent a possible blockage like from a mouse. Double ensure the intake is clear.
It could also be that the transmission is in limp mode so ensure the transmission is shifting correctly.
Change the oil. Hell, change all the fluids! 32,000 on a 1998 still doesn't mean the fluids aren't bad, they still break down over time.
How long has it been sitting?
Old Mar 1, 2011 | 11:53 PM
  #24
jmess's Avatar
jmess
i did an oil change just before winter along with a full tune up. once its a little warmer, or even some time this week, ill be doing a tranny fluid and filter change along with the band adjustment. and its been sitting since around the first of december without running. i bought it in october hoping to get it on the road fast but i lost my job. and before i bought it it was horribly maintained and sat for about a month. and i meand 132k for miles. my bad
Old Mar 8, 2011 | 01:06 PM
  #25
jmess's Avatar
jmess
i know its been a while but i got rid of the strange smell. i put on a new muffler and the smell is gone along with a decent amount of the smoke. theres still a bit of white smoke but its also not in the road and the gas is pretty wet. makes me feel better that it was just the muffler and not a head gasket
Old Mar 8, 2011 | 02:12 PM
  #26
Bobman's Avatar
Bobman
Originally Posted by jmess
Also, what do you mean by tap the cat? Just knock on it to see I it make a hollow sound?
Aww geeeezz..... I just spit Coke all over my keyboard!!!!!
Bob
Old Mar 8, 2011 | 08:45 PM
  #27
MoparMan1991's Avatar
MoparMan1991
You sir, are an awful person! Good catch though.
