low power
first off my truck is a 98 5.9 with 132k. since its getting warmer out and theres a little less snow i finally pulled my d out of the back yard (cant afford insurance atm and needed some work done). did some cleanup, put air in the tires and threw some dealer plates on the truck and went for a drive. i got it onto the highway to clear it all out from sitting. the problem was that the acceleration was horrible. i literally had to have the pedal to the floor to get up to 65 or 70 from about 35. i have a few ideas about the issue. my first thought is that its taking in too much warm air. the tube going into the airbox was broken when i bought the truck so i pulled it off. second is that its simply just been sitting for too long. and third is just a shot in the dark. the truck was horribly maintained by the previous owner and im not sure when the last tranny fluid and filter change was. i plan on doing those as well as a band adjustment soon but could this be an issue on my lack of power? thanks for any help in advance.
It sounds like your air intake may be blocked and your air/fuel mixture is off. I'd take the O2 sensors off and burn them with a propane torch to burn off any remnants off it and make sure they're working properly. Also, it could be a TPS issue. I'm leaning more towards an air blockage problem however.
And the tube intake shouldn't affect the intake so much you're having issues you're having. Check and make sure you don't have a clogged filter. Wouldn't hurt to change it if its been a while.
Trending Topics
Oh god... To be sure check the oil and make sure there's no anti freeze in the oil, and check the level of the anti freeze reservoir, but your suspicions sound like a blown head gasket.
It could be because it's been sitting however normally theres not a funky smell to it. Check oil level as well and I'd recommend puting a can of SeaFoam thru it and cleaning out any deposits that have been sitting.
