Fuse for 20amp 12v outlet
Old Mar 3, 2011 | 12:27 AM
tvogel's Avatar
tvogel
Default Fuse for 20amp 12v outlet
I have a 2000 Dodge Durango with the power outlets. And neither one works. I found fuses under the hood but its good. Any thoughts?
Thanks.
Old Mar 3, 2011 | 09:21 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
there should be fuse in the door jam panel too(least there is in my truck)
Old Mar 3, 2011 | 12:50 PM
hydrashocker's Avatar
hydrashocker
If all the fuses are good, on some models there is a hidden small fuse panel behind the main one in the dash. https://dodgeforum.com/forum/1st-gen...or-lights.html
Originally Posted by logikfive
For the non believers, here is a 2000 harness I removed from a 2000 when I did my dash swap. There are 4 fuses back there. I kept my finger on the yellow fuse covers on the airbag fuses to show the position of the fuse box.
I'll gladly go out and photograph my '99 and look in my '01 and see if I can see the same.
Here is my '99's.. Has two fuses back there. I'm sure the '98's are similar to the 99-00. Your guess is as good as mine as to what they control.
My '01 had no fuses back there. Safe to assume they deleted this hidden fuse panel on the 01+ trucks.
Old Mar 3, 2011 | 02:19 PM
coreybv's Avatar
coreybv
Has anyone ever figured out what the fuses in the "hidden" panel are connected to?
I've read several different posts about this hidden panel, but I don't think I've ever seen mentioned what those particular fuses are actually for...
Old Mar 3, 2011 | 03:12 PM
tvogel's Avatar
tvogel
I forgot about that under the dash panel. I'll check that tonight.
