Issue with interior lights
Old Jan 11, 2009 | 09:54 PM
nealeyandjon's Avatar
nealeyandjon
Default Issue with interior lights
My 98 Durango has developed an interior light issue the interior lights have stopped working i check all the lights i could get to and they were all good
so i checked the amps at the fuse box by the door and it was reading almost 40 amps on a 10 amp circuit does any one have any ideas before i dive in to the dash board this weekend
Jon
Old Jan 11, 2009 | 10:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
If the bulbs are good and fuse #13 has power on both sides of the fuse, Then I would remove a bulb and ck for power on the socket. If you have no power, then you could have a problem with the CTM or cluster.
Old Jan 12, 2009 | 10:49 PM
Mean Green's Avatar
Mean Green
With 40 amps running through there I am really thinking you have a short. Take a look at the electrical diagnosis and testing sticky at the top of the page and see about making a test light to find your short.
Old Jan 8, 2011 | 04:21 PM
R-TICAT's Avatar
R-TICAT
I have a similar (or maybe its the same) issue.
All the interior lights work, when you turn them on with the switches however, none go on when you open any of the doors.
Any ideas?
Old Jan 8, 2011 | 07:24 PM
IndyDurango's Avatar
IndyDurango
Did you check the fuses in the secondary secret fuse box up and behind the obvious primary fuse box?
IndyDurango
Old Jan 9, 2011 | 10:46 AM
R-TICAT's Avatar
R-TICAT
Default Secret Fuse Box?
IndyDurango
Where is it?
Old Jan 9, 2011 | 12:22 PM
logikfive's Avatar
logikfive
You gotta get on your back and look up under the dash at the backside of the fuse box.. For some reason they decided it would be a good idea to hide some fuses and stuff back there.
Old Jan 9, 2011 | 05:44 PM
R-TICAT's Avatar
R-TICAT
Default I See!
Just like the "Old Days", huh?
Old Jan 9, 2011 | 07:24 PM
Biff85ta's Avatar
Biff85ta
Any ideas?
Turn the light *** like your are dimming the dash lights. There is a position past the dome lights on that turns them off even with the doors open.
Old Jan 9, 2011 | 08:29 PM
IndyDurango
Where is it?
Uhhh... "up and behind the obvious primary fuse box"
I'll admit, I did assume that was NOT the "problem" but atlas...never know.
IndyD
