Flat Top Pistons / Valve Clearance?
Old Mar 4, 2011 | 02:26 PM
Sooper's Avatar
Sooper
Default Flat Top Pistons / Valve Clearance?
Planning a rebuild of my Magnum 360 from my 1998 Durango.
Right now I'm assuming a +.030 bore and some flat top pistons.
I just wanted to make sure there will be room in the chamber for the valves to open with a slightly more aggressive cam with higher lift than stock.
Anyone have thoughts on this?
Thanks.
Old Mar 4, 2011 | 11:18 PM
hydrashocker's Avatar
hydrashocker
Here:
Originally Posted by hydrashocker
365 Cubic Inch for .030 bore over? Part #142069
So what rings are you going with? The Premium part# J100F8-4030-5 or Sportsman part# S100S8-4030-5? Or something different?
Heads Gaskets I would intall FEL-PRO Severe Duty Part # 519SD
Also roller the whole thing!
