01 durango haven problems
Old Mar 6, 2011 | 02:34 PM
gpauley's Avatar
gpauley
Default 01 durango haven problems
code says number 5 misfiring. so i changed coil pack and plugs, reset computer and still sayn samething. oh forgot it got 4.7
Old Mar 6, 2011 | 03:00 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Durango section,
FF
Old Mar 6, 2011 | 09:08 PM
hydrashocker's Avatar
hydrashocker
Switch the injector with a different cylinder and see if the problem moves over to it. If it does replace the injector.
Old Mar 6, 2011 | 09:53 PM
master tech's Avatar
master tech
Site Moderator & Tech
More that likely you are dropping a valve seat. Have you also done a compression test too?
Old Mar 6, 2011 | 10:01 PM
WhiteWidow00's Avatar
WhiteWidow00
I agree with both hydra and MT. Is it a constant misfire where it's knocking real bad at idle or is it intermittent?
