my new dilemma: power windows!
Old Mar 8, 2011 | 12:15 AM
MoparMan1991's Avatar
MoparMan1991
Yessir, anything to help. But as stated earlier, try those as they are the cheapest things to do. if you end up needing new switches all around it'll run you about $120 to replace 4 of them. I believe the switches are all the same.
Old Mar 8, 2011 | 11:17 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
sounds to me like his lockout button might be all thats shot, if thats the case the only thing that needs replacing is the drivers side master switch, and if he is ok w/o the lockout i would just jumper it as shown above
Old Mar 8, 2011 | 12:22 PM
Old_School's Avatar
Old_School
Anyone ever have an issue with the windows sticking into place? or maybe something else in there sticking? when i bought my D 2 months ago all the windows worked, the other day all but the drivers rear window would go down.. when i hit the switch i hear a click as it appears to be trying so i know im getting power... not really to worried about it but, just thought id throw it out there incase i decide to try and fix it.
Old Mar 8, 2011 | 01:15 PM
WhiteWidow00's Avatar
WhiteWidow00
Sounds like a regulator going out.
Old Mar 8, 2011 | 04:49 PM
DurangoRT/RN's Avatar
DurangoRT/RN
I have only had problems with my power windows. The driver side has been replaced 3 times and now the back driver and the front passenger are fixed up because they are broken too. I need to fix all three and I can only roll down the back passenger window at the driver door...
Well when I get $ I will have them all fixed. One thing at a time...
Good luck with yours!
Old Mar 8, 2011 | 07:36 PM
MoparMan1991
As of today I have decided that my master switch is goofed up. I tested the switches previously and they all worked so maybe it was just a recent break. What gauge wire do i need to use to make the jump?
Old Feb 2, 2014 | 02:39 PM
s_chev's Avatar
s_chev
Awesome fix. This same problem has driven my family nuts since they couldn't control their windows themselves. 90% of the time they could only be controlled by the driver door switches. Problem fixed.
Thanks!
~Steve
Old Oct 5, 2015 | 08:53 PM
patchelect's Avatar
patchelect
I just found this thread and although I've had issues with my passenger door window, I don't generally carry a passenger so it was never a pressing problem. Wifey is out of town and I decided to do some digging on a few things and discovered this thread. Today I did exactly as shown using #14 stranded wire. She's going to be happy when she gets home!!
Thanks to the original discoverer of the repair. Gotta love these forums!
Old Oct 26, 2023 | 01:10 PM
Phil73's Avatar
Phil73
Default Driver side only
Had same issue with only driver door working, I just ever so slightly bent the pins on control switch to touch up against the female connectors on wire harness, works like new for now.
Old May 20, 2024 | 03:34 PM
Wynterowl's Avatar
Wynterowl
Default Just don't see those colours
Originally Posted by Mastec
Here are the pictures
Just splice the one end of the jumper into the brown wire and the other end into the yellow wire.
Attachment 69184
Attachment 69185
Attachment 69186
Took a total of 5 minutes to complete
I have an 06 Dakota and I just don't see those colours in the door wiring harness (if that's where they are supposed to be) looked under the dash too, but couldn't find them.
Under the dash/steering wheel
Wiring harness at the door for the lock out and pwr windows
