rear end gearing
Old Mar 11, 2011 | 12:37 PM
  #21
moparmuscle's Avatar
moparmuscle
yea im gonna go with 3.92s and i got the stock 235/75 r15 tires right now
Old Mar 11, 2011 | 01:47 PM
  #22
WhiteWidow00's Avatar
WhiteWidow00
That's the exact setup I have on mine! I do heavy towing on a regular basis however so I'm going to be upgrading to 4.56 and 31x/10.50 r15.
Old Mar 11, 2011 | 01:56 PM
  #23
01 6.3L RT's Avatar
01 6.3L RT
Wait UMMM Hydra ...i got tow stuff now cuz she`s got 4.56`s OH DAMN
Old Mar 11, 2011 | 02:22 PM
  #24
WhiteWidow00
6.3, I would say the 4.56 is multi use for both towing and racing! Just not for city driving and every day use wouldn't have much more advantage.
Old Mar 11, 2011 | 05:23 PM
  #25
gr8scott72's Avatar
gr8scott72
Are y'all not listening to me? I lost ZERO mpg in the city going for 3.55:1 to 4.56:1 gears. That's right. ZERO!!!
I lost ONLY 1 mpg on the highway with the 4.56:1 gears.
So, now I can race, er, I mean drive around town with no mpg penalty AND still have great power when towing.
Old Mar 11, 2011 | 11:00 PM
  #26
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
those two statements are contradictory, first you lost 0 mpg, then you lost 1, the two numbers are NOT equal to each other, you might want to be more specific when you mention this in the future
Old Mar 11, 2011 | 11:03 PM
  #27
gr8scott72's Avatar
gr8scott72
Maybe you should sharpen your reading skills.
It's two separate numbers because one is for CITY mileage and the other is for HIGHWAY mileage.
CITY = NO LOSS
HIGHWAY = LOST 1 MPG
Is that clear enough for you?
Old Mar 11, 2011 | 11:10 PM
  #28
shrpshtr325
THE ULTI-MOD
either that or stop drinking while posting(this is all mr. morgans fault), your right, my bad
however your results are still not the norm, most people loose mpgs when going to higher gearing in the rear
Old Mar 11, 2011 | 11:22 PM
  #29
gr8scott72's Avatar
gr8scott72
No worries.
Only sharing what I have PERSONALLY experienced. I've had the 4.56s on there for over 2 years so definitely long enough to know.
Oh btw, LOOSE is the opposite of tight. LOSE is the opposite of gain.
Old Mar 13, 2011 | 02:31 PM
  #30
hydrashocker's Avatar
hydrashocker
Usually you won't loose mileage in the city going a lil lower gearing because it take the engine less effort to get up to speed and that is where you burn the most fuel. When I switched to mine I went from 4-6 MPG's in the city to 8 MPGs in the city.
On the hyw, well just did the mileage last night with only 1 quick stop, went 79 miles on 7.2 Gal so I got 11 MPG. I went down like 1-2 MPG's but were talkin about a V10 and not a V8.
What I'm tryin to say is, the best thing is to do your home work and use a calculator one of these: http://www.ringpinion.com/Calculators.aspx and find out your optimal engine RPM for torque curve and HP and the speed that you usually travel. Then get tires and gearing to get you to that optimization.
In my truck, my best is between 2500 and 2900 RPM's. So with my tires and gearing I will be pulling my trailer at just under that because I was shooting for fuel mileage as well. At 75 mph I am at 2350 RPM in overdrive. But that leaves me room so when I down shift like on hills that I can keep my power band or when runnin hills and city I can lock out and run in the 1-3 gears.
Remember, my trans says I can tow in overdrive, but the Durango's does not!
