PO038 code
Old Mar 14, 2011 | 07:41 PM
mb98d's Avatar
mb98d
Default PO038 code
My 03 d is giving me a po038 code and i am trying to find out if i should just replace the downstream sensor or if its more likely that i have a wiring issue or ecm issue?
Old Mar 14, 2011 | 08:06 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its most likely that the sensor or plugs are bad, there is no ecm in dodge vehicles, they are PCM, the differences are subtle, but important, it is possible that you simply got water in the connector
P0038 HO2S Heater Ctrl Circ Hi Bank1 Sens2
i would clear the code and see if it comes back
Old Mar 14, 2011 | 11:14 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does your 4.7 have a power steering switch coming off the pressure line?
Old Mar 15, 2011 | 08:17 PM
mb98d's Avatar
mb98d
@shrpshtr325 I did clear the code and it came back on within a minute or so of start up.
@mastertech I'm not sure I'll have to check tomorrow. What is the relivence of a power steering switch to an o2 sensor code?
Old Mar 15, 2011 | 08:32 PM
WhiteWidow00's Avatar
WhiteWidow00
The issue is it's not uncommon for the power steering switch to leak and the fluid leads down to the sensor wiring an causes a short. It happened to me and it was a PITA to trace down and ended up being simple as replacing the switch and cleaning up the wires.
Old Mar 15, 2011 | 09:55 PM
shrpshtr325
THE ULTI-MOD
the ps switch and the o2 sensors share a poriton of the wire harness and power steering fluid can leak into the harness and cause a short
Old Mar 16, 2011 | 10:02 PM
mb98d's Avatar
mb98d
i see. thanks for the advise. i will check for ps fluid leaking onto the wiring harness and if thats all clear i'll replace the sensor. here's to hoping
Old Mar 16, 2011 | 10:37 PM
WhiteWidow00
If it's got a leak it will look a little something like this. This is what mine looked like before I fixed everything. Granted mine's a 5.9 and yours is a 4.7, but should look like this if you have a leak.
Old Apr 23, 2011 | 02:04 PM
surfales's Avatar
surfales
Is there a happy ending to this story?
Old Dec 16, 2011 | 12:36 PM
Allen Dodge28's Avatar
Allen Dodge28
On a 3.5 motor, is the P0038 code for the front or the rear sensor?
