knocking and oil presseure drops after warming up
Old Mar 19, 2011 | 02:53 PM
tagw2006's Avatar
tagw2006
Default knocking and oil presseure drops after warming up
I have a 99 Durango 5.2 4WD. After the motor gets hot oil pressure drops and starts knocking. I've heard it could be the oil pump or main bearings? Any advice? Thanks
Old Mar 19, 2011 | 06:50 PM
hydrashocker's Avatar
hydrashocker
What oil do you have in it? 10W-30
Old Mar 19, 2011 | 07:13 PM
WhiteWidow00's Avatar
WhiteWidow00
And how much does the pressure drop? The pressure is supposed to drop when it gets warmed up but supposed to stay within the lines at all times.
Also, yeah like hydra asked, what weight oil is in it? I had a customer one time that brought in their Durango that they took to some Mom n' Pop store to change their oil and they put 15w-40 in it (a.k.a. Diesel oil) and it was knockin' pretty hard.
Old Mar 20, 2011 | 02:40 AM
47durango's Avatar
47durango
man guys i have a similar problem too. i have an 4.7 1999 drango. it has an little oil leak from driverside valve cover. when it warm up the oil gauge drop all the way to 0. any advice will help. some times gose up and down.
Old Mar 20, 2011 | 02:44 AM
WhiteWidow00
I'd get that valve cover gasket replaced ASAP!
Old Mar 20, 2011 | 09:07 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ummmmm, no you dont, the 4.7 wasnt available until 2000 . . .
Old Mar 20, 2011 | 09:14 AM
MAGIC84's Avatar
MAGIC84
Damm Sharps....you beat me again!!!!
Old Mar 20, 2011 | 10:20 AM
47durango's Avatar
47durango
got your noise. yes its an 1999 but surly its an 2000 model. kinda new on dogde. but can an valve cover leak can cause the oil pressure to misfuntion.
Old Mar 20, 2011 | 11:56 AM
WhiteWidow00
Yes it most certainly can. Put your hand over your mouth and try to breath in, now create a small opening between your fingers and take a deep breath. Notice the pressure difference..?
Oh and for the record you go by model year and not production year. Mine too was manufactured in '99 but a 2000 model.
Old Mar 20, 2011 | 04:09 PM
hydrashocker
Replace the oil filter and change the oil. Could be a plugged oil filter.
