Transmission Advise
I've never heard of ATF+5, only -5. But if they can show you some bottles of ATF+5 then I suppose that's what they really did put in there. At least they didn't dump dexron or mercon in there, but not using certified ATF+4 will certainly decrease the life span of the trans and cause weird problems.
Here's a site I found, looks legit I guess. I believe chrysler is still using ATF+4 to this day because they keep improving the formula.
http://www.centerforqa.com/home.html
Well then I guess my best option if they dont show me the bottles is wait a week to see if the Truck is infact fixed and then bring it to another shop and have them flush and refill with ATF+4. I just dont want to do it until I know it does not need to go back as they most likely would not refill it with the same.
thats a different thread widow, i just re-read this one and he hasnt opened the pan up by himself, only the shop has, and flushing the cooling lines is what i believe we suggested in that case(or maybe flushing it before it was rebuilt)
heres the guy your thinking of https://dodgeforum.com/forum/1st-gen...-problems.html
Someone got the shaft!
I was thinking about this (and yes I'm sober right now) and I think I understand what they were talking about. I bet they used 5+ quarts of ATF on the refill......LOL....Meaning they used the incorrect fluid anyway. That sounds more plausible!
And there is the conflicting information. I had heard they where formatting a new fluid for the newer trucks, but the fluid is a DEALER ITEM ONLY! Didn't know they actually had it in anything other than a test truck, well I guess they are "testing" it in a truck, one that doesn't have the warranty like the other trucks hints the use in the 2011 Ram 4500........LMFAO
Can you get a manufacture name off the bottle?
I thought that was my designated line.....Better move over......LOL
Well it's confirmed ATF +5 is real but rarely used. In fact we only have a couple 5 gallon jugs of it in the shop rather than a huge quantity of it. Its a not commonly used fluid and is actually recommended in the new 2011 Ram 4500 and nothing else that I've serviced yet.
I just know ATF +5 is a dealer only fluid and yes hydra, I will get that part number for you when I go in...
