T/S Bar and Shackle lift with a twist
Old Apr 5, 2011 | 01:03 AM
Evon Trizmo's Avatar
Evon Trizmo
Default T/S Bar and Shackle lift with a twist
Alright so here's my question, I've been planning on doing this lift for quite a while now and here's the big question. Is it possible to make the rear of the leaf spring stationary and add shackles to the front of it or am I out of my mind? haha. The reason I'm asking is the shackles stick out way past the rear bumper (unless I get an SP360 body kit) and look pretty obvious, with the running boards installed, shackles on the front of the spring would be barely noticable. If it's not possible I'd rather just go with add-a-leaf or something.
I would assume the longer shackles would give it a slighty smoother ride in the back but of course it will be more harsh up front. When we offroad and jump the rear passengers always get thrown around up in the air and beaten up from whiplash and whatnot back there, the front just sinks and hits hard once haha.
Old Apr 5, 2011 | 01:11 PM
hydrashocker's Avatar
hydrashocker
No it's not posible because the rear end could never be stationary enough to align the truck, and you have to have a stationary pivot point for the main wheel torque to flow into the chasis.
You have 2 choices as I see to acomplish your goal of not seeing the shackles hanging down,
1. Add-a-leaf
2. New longer and arched leaf springs.
Personally, I would do the new leaf springs and call it a day. Your going to have a better all around ride from the rear. Front would still be a bit stiffer then normal but not much.
Old Apr 5, 2011 | 01:21 PM
Evon Trizmo
Ah, ya that's what I was thinking, just getting a new set of leaf springs for more lift, but you know always taking the cheap way out haha. The add-a-leaf sounds like more work than it's worth. Just thought I'd throw it out there and ask.
Old Apr 6, 2011 | 12:12 PM
bowhuntmaine's Avatar
bowhuntmaine
Its a more harsh ride but u can put overloads on it to. Jack up the rear at the last crossmember until both wheels are off the ground and you have max sag, bolt on the overloads and lower it. It evens it out perfectly with the torsion bar adjustment (atleast it did on mine). Overloads are 35 bucks at autozone.
Old Apr 6, 2011 | 12:24 PM
Evon Trizmo
That's another way to do it. The rear springs seem a little weak and longer shackles won't help that out at all but overloads will stiffen it up a bit. We had 4 guys in the back of my D and the rear suspension was just about maxed out, looked like a broke something out on the trail haha.
Old Apr 6, 2011 | 12:38 PM
bowhuntmaine
I had 8 bags of cement in the back (80 lbs a piece) 640 or so pounds, and it didn't squat it more than an inch. Its a rougher ride and i have no need right now for articulation.
