Strange problem has me stumped and broke down
#23
Then you test the middle wire which should be around 0.5 volts (performance tuned to 0.70 - 0.75) volts and should not be fluxuating because the engine is not running. As the throttle plate opens, the volts increase coming out of the middle wire from the TPS to tell the PCM that the throttle is opening so to increase fuel. The maximum voltage you should get out of the TPS is 4.5 volts however and that would be at Wide Open Throttle (WOT).
When fully closed I'm getting around 6.1 volts and it doesn't change at wide open throttle. That was with me probing center wire with red and black grounded on neg battery cable.
No different in 1 or 2. I tried that one today too. Yeah, I think you're right...above my mechanical qualifications.
Now your saying that on the VT/WT wire (closest to cab) that the input is 6.1 volts measured by testing the wire at the plug and your negative wire is grounded to the battery? And you have tested across the battery post to ensure your multi-meter is calibrated correctly? This is a problem as you should have only no more than 5 volts going to the TPS.
Now you also state a different problem, the voltage coming out of the TPS (middle wire) OR/DB is the same voltage as going in with the throttle body in the closed position. This means that the TPS resistor is burned out and allowing full in and out voltage. This means you need to replace it.
Now if I got all of your information correct, I would tell you to replace the TPS and the PCM as the regulator in the PCM is shot and sending too many volts (over 5 volts) to the TPS and most likely to the other portions of the truck that are regulated down to 5 volts like the MAP, CPS, TPS, Cam sensor, and a number of others.
#24
Thanks Hydro...I hoped you would see this and chime in with your valued opinion. That was my fear all along...PCM. It was odd because I still have no error codes whatsoever.
Today, I put a new battery in only because one was available to test at no cost. Of course it didn't help as my battery was fine.
I did calibrate the multimeter based on the battery and it was reading correctly. I also replaced the TPS again just in case the on I had was bad but it didn't work. I tried power-braking her to "test" torque converter but that didn't help either. I think the torque converter is fine as I experienced no issues with transmission up to the moment all went south. Plus, reseting PCM resolves issue for about 1-2 minutes.
I'm going to have it towed to by Dodge tech's house next week. Not that there are any "good" times for this to happen but the next couple of weeks are particularly hard financially so it's really bad timing. Hard to run a service business without wheels!
Thanks to everyone for your assistance and I'll update you all when it is resolved.
#25
#26
Thanks again Hydra. I checked them out on ebay and noticed one of the vendors in in Charlotte, NC and a lot of my work is in Charlotte. I'm going to call them Monday morning and see if I can drop it off for pick up on Tuesday. Hope they give me a price break because they are $295 for the 5.9L. The Florida company will repair mine for $124.00 but I imagine it will take much longer due to shipping back and forth.
