Does Anyone Know!!!
Old Apr 10, 2011 | 08:54 PM
Kevin Murphy's Avatar
Kevin Murphy
Default Does Anyone Know!!!
I have a 1999 D, does anyone know what the sensor under the battery is?
Old Apr 10, 2011 | 09:00 PM
WhiteWidow00's Avatar
WhiteWidow00
Battery Temperature Sensor. It uses the temperature to calculate the intake air density and target charging system voltage.
samnbensdad's Avatar
samnbensdad
Old Apr 10, 2011 | 09:01 PM
samnbensdad
Damn it Widow...
Old Apr 10, 2011 | 09:04 PM
Kevin Murphy
Question Question
Would this make the engine stall after 15 minuets
samnbensdad
It's also used to control the electic fan. If you have one...
Old Apr 10, 2011 | 09:12 PM
WhiteWidow00
Yes it can because it controls the charging system and if it is malfunctioning it will throw your charging system all out of whack and cause it to stall once your battery isn't able to supply enough voltage.
Replace that sensor and that should be your fix!
Old Apr 10, 2011 | 09:16 PM
Kevin Murphy
Question Stalling
The D would run Great for 15 minuets then stop like you shut it off. unplugged it and the D ran fine
Old Apr 10, 2011 | 09:21 PM
WhiteWidow00
That is because it is basically killing the charging system (alternator to battery) and when you unplug the sensor, it bypasses it and uses a factory setting.
Old Apr 10, 2011 | 09:25 PM
Kevin Murphy
Thanks for that information. Will order a new one. Will it hurt the D if I run without it?
