Gauge Cluster
Old Apr 18, 2011 | 08:38 PM
logikfive's Avatar
logikfive
I have a pretty good idea what the outcome will be on this. Only difference is it was the other way around (I swapped my '01's cluster for an '00 cluster).
Pick up a cluster and let us know the outcome, that's probably the only way you're going to know for sure.
On your '00 cluster, since your truck obviously has the mechanical shift indicator, where is your "OD OFF" light and "Cruise" light? Are they bulbs like the "Low Wash" and "Check Engine" lights or are they located in the odometer display?
Old Apr 18, 2011 | 08:43 PM
WhiteWidow00's Avatar
WhiteWidow00
My O/D off light is actually an illuminated light in the cluster however the cruise is in the odometer area.
With your swap were there any issues with anything plugging up or how was the swap with the indicator?
Old Apr 18, 2011 | 11:01 PM
hydrashocker's Avatar
hydrashocker
Originally Posted by WhiteWidow00
This may sound like a stupid question but... Would the gauge cluster from a 2001-2003 Durango fit on my 2000 Durango? Mine has the old style and not the "Information Center" style one and I'm wanting to change it up a little bit.
Please, I'm asking those who have experienced it or a confirmed answer and not a "I'm sure it would work" because yes I'm sure it would work but before I buy a $50 cluster from the junk yard I want to make sure it will work.
I don't think it will work, sorry I don't have a better answer for you.
You could always spend your cash on a new cluster back ground!
Old Apr 18, 2011 | 11:54 PM
MAGIC84's Avatar
MAGIC84
Look at the big brain on Hydra. Try this link, they can send instrument panel overlays.
http://www.blackcatcustom.com/specia...%20durango.htm
When Indy D gets back from vacation, he should chime in....... the one he did on his 2000 looks sweet.
Old Apr 19, 2011 | 06:36 AM
WhiteWidow00
Yeah that's what I'll probably end up with. I was trying to change it up and indeed hydra, I think a background will be the way I'll go because I think it would be a waste of time and effort but I wanted to get other opinions.
Thanks guys and Indy, feel free to give your .02 on this matter and pictures would be great!!
Old Apr 19, 2011 | 12:31 PM
kingoftow's Avatar
kingoftow
Default airbag/clockspring...
Hey thanks widow and sharp...that puts my mind at ease. I'll check the fuse later when my wife gets back with our D, my horn and cruise aren't working so it may be the clockspring. Hope it's still available and not too expensive...kingoftow
Old Apr 19, 2011 | 02:34 PM
WhiteWidow00
Yes a clockspring is available and no it's not expensive.
Old Apr 19, 2011 | 11:17 PM
hydrashocker
Well they look cool and you can get them in lots of colors including new dials pointers as well.
Old Apr 20, 2011 | 01:57 AM
IndyDurango's Avatar
IndyDurango
OP, the 2001+ D cluster will not work on a 2000- Durango.
IndyD
Old Apr 20, 2011 | 06:31 AM
WhiteWidow00
Thank you Indy, that is the answer I was looking for. Off to other places to look for gauge cluster inlays!!!
