water pump and fan clutch toast
Old Apr 20, 2011 | 01:48 PM
Durango03's Avatar
Durango03
Default water pump and fan clutch toast
I'm on vacation and the water pump went dis lodging the belt and had to limp it into a shop. New water pump, HD clutch, belt, fluid and labor $420. But my question is, when I got it back to the Hotel, I popped the hood and I can spin the fan. Is that normal? I thought if you could turn the fan easily by hand that meant the clutch was bad??
Sean
(Currently in Myrtle Beach)
Old Apr 20, 2011 | 04:54 PM
samnbensdad's Avatar
samnbensdad
It's not locked into place; you should be able to move it by hand. Try spinning it (like you're playing wheel of fortune ) If it spins less than about 1/4 turn then you're fine. It should not spin freely though.
Old Apr 20, 2011 | 05:03 PM
srch4me's Avatar
srch4me
the clutch is fluid filled... the fan will always be able to turn... just depends how far it turns... i blew my waterpump 2 months ago and changed it myself...
Old Apr 21, 2011 | 07:42 PM
Durango03's Avatar
Durango03
Ok, another question..... This HD fan clutch they put on is VERY Loud! Is this normal? Its probably twice as loud as before!
Old Apr 21, 2011 | 07:51 PM
98SLT4ME's Avatar
98SLT4ME
I can spin my fan all the way around freely and it doesn't stop. But I have no problems with cooling or anything else.
Shop also said my fan clutch was fine.
Old Apr 21, 2011 | 08:41 PM
WhiteWidow00's Avatar
WhiteWidow00
Yes, there has been many discussions regarding it and the final conclusion was that the HD clutches are much louder than the standard duty clutches. That being said though it is cooling that much more so it's a give and take.
Old Apr 21, 2011 | 10:11 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its fine as long as you dont have problems or do alot of highway driving, but if you tow or sit in traffic you will likely overheat, that clutch is pretty much worn out
Old Apr 21, 2011 | 10:16 PM
98SLT4ME's Avatar
98SLT4ME
I have sat in plenty of traffic and it has stayed cool. It's weird. I have a 180 deg. stat installed but I doubt that keeps me from overheating. The fan obviously still works when it needs to. When Im sitting idling, the fan spins sufficiently. Like I said, its weird. Been like that for a while.
Old Apr 22, 2011 | 10:02 PM
Durango03's Avatar
Durango03
Well, I believe it will act as a gas saver for me, cause I dont like hearing it.... hahaha
Old Apr 23, 2011 | 06:54 AM
WhiteWidow00
I believe we call that a WIN-WIN! LOL
