Just plain stuck
Old 05-05-2011, 09:27 PM
neilb's Avatar
neilb
neilb is offline
Wink
In my day we would have dug it out with a tea spoon!
Old 05-05-2011, 09:54 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
old fart
Old 05-05-2011, 10:27 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
...and this is why I am running Mickey Thompson Baja MTZ tires! Imagine that, except you're pulling 6,000# behind you! Been there, done that! LOL
Old 05-05-2011, 11:07 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Originally Posted by Groggy
How do chain's do in the sand? I see more sand than anything else... Now I'm thinking about a set!
Never tried em in sand?
Usually you want a good tire like a TSL and you lower the PSI down to about 15 psi so you get a very large track pattern.
Old 05-06-2011, 11:49 AM
topdogcustoms's Avatar
topdogcustoms
topdogcustoms is offline
+1 Hydra
they dont work in sand makes it worse. air down and burp the gas a whole bunch of times to get back on top of the sand!!!!
Old 05-06-2011, 09:16 PM
redfernclan's Avatar
redfernclan
redfernclan is offline
Originally Posted by Bobman
Ummmmm.... yeah. Right.
That stuff is like driving in soup. The surface is juuusssttt firm enough to walk on, but one you break thru it you might as well give up. I got my tractor buried behind my pond just dragging a bunch of tree limbs back to burn. Walked on it with no problem, drove the lawnmower over it with only a little bit of squishing, but once I broke the surface with the wheels of my 8N it just sunk. The more you move the deeper you get. Sure makes a hell of a rut to fill when you're pulled out too!
Bob
Sounds like exactly what I was driving in. If anything, tires had to much traction, no that doesn't sound right. Problem was driver hit the gas to hard, spun all four tires and spit out the grass and sod that was holding me up. No ruts, no tracks to rock it back and forth, so down I sit on the diffs and frame.
Old 05-07-2011, 09:56 AM
redfernclan
This is what I was trying to get. It was pretty soupy under the turf.
Old 05-07-2011, 02:42 PM
hydrashocker
Now that looks like fun.....
Old 05-09-2011, 09:00 AM
Bobman's Avatar
Bobman
Bobman is offline
A roll cage? Was that factory stock?
Bob
Old 05-09-2011, 12:34 PM
redfernclan
I'm sure it was an option, just like the cut off hair gel can on the stack. ;]
Quick Reply: Just plain stuck
