acceleration studder when cold
Old May 12, 2011 | 12:05 PM
DylanHatcher's Avatar
DylanHatcher
Angry acceleration studder when cold
I get up for school at 6 in the morning get in the truck, put it in drive, it takes a few seconds for drive to engage and then as i go down my drive way it feels sluggish and then bucks every 2 seconds. now this is one of the many problems with my durango but i love her so i have to fix it any ideas?
Old May 12, 2011 | 12:19 PM
Tshane72's Avatar
Tshane72
Hey Dylan, I'm no expert, but have u checked the transmission fluid level lately? Anything leaking under the truck that you know of? Gotta start somewhere!
How many miles are on the truck? Been keeping up on tranny fluid changes and flushes?
Old May 12, 2011 | 12:29 PM
samnbensdad's Avatar
samnbensdad
Can you rev the engine while in Park without hesistation? If it just happens while moving it may be a transmission issue. Tranny fluid naturally expands quite a bit as it heats up, so it takes up less room when it is cold. You may be a little low on fluid. Do the following to check the fluid:
  • Drive ~15 miles
  • Shift through all gears (a few seconds per gear)
  • On level surface, put in Neutral (pull emergency brake/ block wheels)
  • Check dipstick
If it is low, add ATF+4 ONLY
Old May 12, 2011 | 02:53 PM
topdogcustoms's Avatar
topdogcustoms
+1 samnbensdad
Old May 12, 2011 | 08:18 PM
DylanHatcher
it has 120,000 and no leaks from the tranny perfect colored fluid and at a perfect level i can rev it in park no problem, im going to flush the tranny tomorrow and put some new fluid in it and see where it goes
Old May 12, 2011 | 08:21 PM
samnbensdad
Drain only. Do NOT flush!!!
Old May 12, 2011 | 09:58 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
NEVER flush a transmission, always drain and replace the fluid.
Old May 13, 2011 | 12:04 AM
hydrashocker's Avatar
hydrashocker
Sounds like you need to do a classic fluid and filter change. Replace the fluid with ATF+4 fluid only.
Old Jun 20, 2011 | 11:14 AM
DylanHatcher
sorry its been a while away form the computer but my transmission blew 2 days after putting up the post i went down to the junk yard and got a new torqu converter, transmission and transfercase for 500 and put it in this weekend with my buddy only took about 4 hours and a **** load of hitting out heads on the frame rails and brackets
