Break Line leak?
Old May 22, 2011 | 05:57 AM
CtownChris's Avatar
CtownChris
Default Break Line leak?
Went to get gas about 1 mile last PM. Noted mushy brake on way home.
As I pulled in the drive the Brake and ABS light went on in the dash.
Noted a few spots on the drive and found a leak on my rear driver side where the hose meets the metal line.
Can I safely drive it to the shop or do I need a tow.
I will top of the reservoir and carry extra fluid for the 5 mile drive.
I doubt it is just loose but corroded or cracked line.
Old May 22, 2011 | 09:44 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you take it very very easy you will probably be fine it all depends on how bad the leak is, if it only leaks when you press the brake pedal and you dont have to stop much you will probably make it to the shop just fine, however without knowing all the details i really dont have a straight answer for you.
keep in mind if you DO decide to do this that the e-brake is cable driven and is still there even if you loose the hydraulic brakes, its not fun to stop with, but most certainly can be done.
Old May 22, 2011 | 09:47 AM
samnbensdad's Avatar
samnbensdad
Is it safe? Envision this: you are driving by a house and a kid chases a ball into the street. Your brake lines are low on fluid. You step on the brake pedal and it goes to the floor...
Is it worth $50 tow truck bill??? Think about it as an insurance policy...
I don't mean to sound like a total jerk, but it really isn't just about us and our trucks.
Old May 22, 2011 | 09:48 AM
CtownChris's Avatar
CtownChris
Thanks Shooter. Kinda what I was thinking, Engine brake and least amount of stops for my route.
Only leaks with pedal pressure so I'm not losing fluid at rest.
Old May 22, 2011 | 09:52 AM
CtownChris's Avatar
CtownChris
I have AAA and tow insurance with my auto policy.
Guess I'll call for a tow.
Makes sense.
I made it home OK and no reason to play games.
Old May 22, 2011 | 09:56 AM
samnbensdad
For those of us with children... Thank You!!!
Old May 22, 2011 | 02:55 PM
hydrashocker's Avatar
hydrashocker
I agree with getting towed as well.
Old May 22, 2011 | 03:06 PM
WhiteWidow00's Avatar
WhiteWidow00
I agree too. When it comes to some things I'd say it might be worth the risk but the ability to stop a 6,500 lb vehicle, it's not worth the risk especially if you can get a good rate on getting towed there.
Old May 22, 2011 | 03:52 PM
hydrashocker
Hell,
My insurance company has "Towing" coverage and it was either free or I pay a buck or so for it and they cover up to $100 bucks of towing charge with receipt of the actual charge. All I have to do it take it/send it to a Met agent for a check. However I think AAA has it built into their policy. Regardless, I think everyone should know about the coverage, or at least look at the actual coverage you already have.
