Transmission Q's
Old Jun 5, 2011 | 02:29 PM
  #31
MoparMan1991's Avatar
MoparMan1991
Its only 65 to 100 for the jeep controller and every case I've heard of has worked, but not on 2000 durango/dakotas or older due to a different computer communications system. You can still do it but your shift indicator will stay lit up and you'll get a code thrown but as far as I've read its still doable. I've read the thread (12 pages) about three times to make sure everything will work. I'm at work now so when I get off at 11pm central ill post the link to the thread. You can also go to dodge talk and search for the forum. I think its 45RFE to 5-45RFE or something like that.
Old Jun 6, 2011 | 02:48 PM
  #32
master tech's Avatar
master tech
Site Moderator & Tech
If you go ahead and use the jeep controller. Let us know how it works out.
Old Jun 23, 2011 | 03:48 AM
  #33
MoparMan1991
Originally Posted by master tech
Okay the number you posted is for a jeep grand chrokee 4.7 with a 5 speed controller. If you want the durango controller for 4.7 engine, its 56040617AE and its been supersedenced to a RL040617AK. This is a mopar reman part number and it will need to be program by the dealer. 2002 was the last year for the TCM as a stand along controller, because in 2003 the TCM became part of the JTEC/PCM controller.
I know im reviving an old thread but Master Tech, I've done google searches on both numbers and haven't come up with much. Any info you can find?
