oil change time...
Old May 26, 2011 | 01:34 AM
OffTheTimeline's Avatar
OffTheTimeline
Default oil change time...
So for those who don't know, I have an 02 SXT 4.7L 4x2. What is the best oil to use and what weight?
Old May 26, 2011 | 06:13 AM
topdogcustoms's Avatar
topdogcustoms
Mobil 1 10w30
Old May 26, 2011 | 07:18 AM
Bobman's Avatar
Bobman
+1 I made the switch and won't go back to a "regular" oil again.
Old May 26, 2011 | 07:38 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the best bet is probably mobile one, but i have been running shell in mine as long as i have been driving it with very good results
make sure to consult your owners manual for the correct weight, i believe it calls 5w30 and 10w30 acceptable for the engine, but there are two different charts in there, each one has a different preferred weight(idk about other years, but 02 does have this)
Old May 26, 2011 | 11:02 AM
OffTheTimeline
Cool thanks everyone!
Old May 26, 2011 | 12:40 PM
98RangoSLT's Avatar
98RangoSLT
I just put Havoline conventional in mine and installed a Purolator Pureone filter. I would recommend the Pureone filters, they are one of the best and you can get up to four of them for about $3 each after rebate right now.
Since my 98 has almost 126k on it and I know that is has seal leaks, I will be sticking with dino oil. I am sure Mobil 1 would open those leaks right up.
Old May 26, 2011 | 03:07 PM
rob[GL]'s Avatar
rob[GL]
I just use whatever is on sale at Walmart. Usually Pennzoil, sometimes Quaker State, and this weekend I just did an oilchange with Castrol GTX... I use conventional 5w30 and a cheap FRAM or K&N oil filter.
I love doing oil changes. It's such a quick and easy job, I can't believe people pay quick-lube places $60-$120 (depending on oil, filter, etc) when it's something you can do at home on the weekend for $15.00
-rob
Old May 27, 2011 | 01:19 PM
hydrashocker's Avatar
hydrashocker
I use Mobil One 10W-30 Fully Synthetic and usually get a Bosch filter.
Old May 28, 2011 | 02:36 PM
98RangoSLT's Avatar
98RangoSLT
Boschs are currently rebadged pureones by the way.
Old May 28, 2011 | 06:42 PM
WhiteWidow00's Avatar
WhiteWidow00
I use Mobil 1 Full Synthetic with a Royal Purple filter. Royal Purple IMO makes the best filter and to those who think Mobil 1, K&N, and Royal Purple are all the same filter, you're wrong because I've cut open all 3 and they all look different in their own ways.
As for Bosch filters being re-badged PureOne filters, I have to disagree simply because about 5 years ago they were doing that but since then there's been tests done that in fact it depends on where you get it from that is what's inside the filter housing. Last I checked the AutoZone Bosch filters use the same filter element as a PureOne but I bought a PureOne and a Bosch from Wal-Mart about a year ago to cut it open and it was 2 completely different ballgames.
