Speaker Question.....
Old Jun 21, 2011 | 09:03 PM
harleytech's Avatar
harleytech
Question Speaker Question.....
Hi, I checked all the do it yourself threads on speaker replacement and I just wanted to ask one question that I couldn't find. Are the tweeters wired to the Mid/woofers or are they wired to the headunit/amp ? Meaning do all the speakers including tweeters have a set of wires going to them or are the tweeters piggybacked off the woofers ? I have the 8 speaker Infinity system. Thanks...
Old Jun 21, 2011 | 10:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
iirc the tweeters are not wired to the larger speakers (i believe they are mids but dont quote me on it) once you pop the doors off you will see the wiring, setup, its NOT hard to take the inside door panel off
Old Jun 22, 2011 | 06:53 AM
harleytech's Avatar
harleytech
ok, but if I buy speakers + Tweeters w/ a crossover unit do I wire them up with the stock wiring or do I use the crossover unit that came with said speakers and tweeters ?
Old Jun 22, 2011 | 03:38 PM
topdogcustoms's Avatar
topdogcustoms
If your going to use the factory amp the speakers need to be 2ohm
Old Jun 22, 2011 | 04:19 PM
harleytech's Avatar
harleytech
Roger that....! I Know....Thanks..
Old Jun 22, 2011 | 04:26 PM
shrpshtr325
THE ULTI-MOD
i would use the stock wiring, but thats just me it might not be correct
Old Jun 22, 2011 | 04:58 PM
WhiteWidow00's Avatar
WhiteWidow00
If you bought what it sounds to me like you got a component system. What you are going to do is use the stock wiring leads from the factory amp or stereo deck (which ever feature you have) and that is going to be your supply for the crossover. You are then going to want to utilize the crossover as the supply for the speakers.
Old Jun 22, 2011 | 05:43 PM
harleytech's Avatar
harleytech
Ok, Great..! That's all I needed to know....As always, Thanks Guy's....!
