Bump stops... no clearance.
Old Jun 28, 2011 | 10:48 PM
mvoss2576's Avatar
mvoss2576
Default Bump stops... no clearance.
Replaced the worn bump stops today
But.. the passenger side doesn't have any clearance
Drivers side... looks a little better..
What can I do to cure the spacing on the passenger side?
Old Jun 28, 2011 | 11:07 PM
srch4me's Avatar
srch4me
have your suspension checked... your passenger side could be riding lower than the drivers side... check the shocks and such... might the the t-keys
Old Jun 29, 2011 | 12:19 AM
IndyDurango's Avatar
IndyDurango
My '00 slightly touches on both sides, has for years.
The jounces deteriorate from the weather, not rubbing. That foam stuff they are made of isn't as resilient as rubber would be.
IndyDurango
Old Jun 29, 2011 | 09:46 AM
mvoss2576's Avatar
mvoss2576
Yeah.. that foam stuff costs plenty doesn't it..
I'm gonna get it checked out pretty soon... man this thing is sucking up the 'extra' money that I had hoped to save by buying it.
Old Jun 29, 2011 | 10:04 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
im going to 2nd what indy said, mine touch too and have for as long as i can remember.
Also, while that sucks, thats a chance you take buying a used vehicle, especially one thats 12 years old, but think of it this way, once you get it fixed it will stop sucking up your money.
Old Jun 29, 2011 | 01:49 PM
hydrashocker's Avatar
hydrashocker
It is never supposed to be like that!
Your ride height has been lowered or your T-bars have lost some of the tention. You need to reset the factory ride height and get an aglinment. https://dodgeforum.com/forum/1st-gen...ment-woes.html
After you set the ride height back to factory (because the techs are to lazy to do it right in the first place) you need to tell them NOT TO TOUCH THE HEIGHT! They can aglin it without touching the height.
Old Jun 29, 2011 | 02:28 PM
mvoss2576's Avatar
mvoss2576
Thanks Hydra... kind of what I was thinking.
Old Jun 30, 2011 | 12:49 AM
IndyDurango
What money? They take 2 minutes to replace and cost like $10 a pair. Check under your couch cushions. Expect the dealer to sell you "bearings"
IndyD
Old Jun 30, 2011 | 08:57 AM
mvoss2576's Avatar
mvoss2576
IndyD
Where did you find them for $10 a pair.. I bought these for like $57 from the dealer. The ones I found on ebay (which were wrong) were $35(with shipping) for the set..
Old Jun 30, 2011 | 09:10 AM
Freedog's Avatar
Freedog
My bump stops are trashed and I noticed that they sit awfully close to the lower control arm as well. My Durango sits level though so does it make sense that the suspension has sagged equally at all four corners? Well, I have the factory service manuals so I'll have to check the ride height and see whats up.
