My 99 durango wont start now.....
Old Jul 7, 2011 | 10:14 PM
  #21
hydrashocker's Avatar
hydrashocker
Get a fuel pressure tester and get the actual reading from the fuel rail.
Old Jul 8, 2011 | 07:32 PM
  #22
bkohne1's Avatar
bkohne1
Well that is a good idea if the truck would stay running. Since it wont run i cant get a reading. I just ordered a fuel pressure regulator, so we will see what that does.
Old Jul 8, 2011 | 09:05 PM
  #23
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you can get a reading off the rail without the engine being on, just turn the key and the pump primes the system and you can get a reading
Old Jul 9, 2011 | 12:45 AM
  #24
hydrashocker
+1 Sharps
The fuel pump is electrical.
Old Jul 9, 2011 | 02:15 PM
  #25
topdogcustoms's Avatar
topdogcustoms
+2 Shrp
Old Jul 11, 2011 | 09:24 PM
  #26
bkohne1's Avatar
bkohne1
So i got the regulator today and discovered it was the wrong one after i had the fuel pump assembly out and disassembled. However, i did notice the new "fuel hose" that came with the new pump was not tight on the nipples. It is a cheap plastic hose that wont tighten all the way. I took it off and replaced it with real fuel line, put it all back together and it fired right up and ran perfect!
Old Jul 12, 2011 | 12:05 AM
  #27
hydrashocker
So does that mean you replaced the fuel pump or not?
Old Jul 12, 2011 | 12:25 PM
  #28
bkohne1's Avatar
bkohne1
yes the fuel pump was replaced.
