My 99 durango wont start now.....
Old Jun 30, 2011 | 07:28 PM
bkohne1's Avatar
bkohne1
Default My 99 durango wont start now.....
I have a 99 durango with the 5.2. I went to leave work and it started for a split second and then died. Now all it does is crank but wont fire. Any ideas?
Old Jun 30, 2011 | 07:59 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
try holding the gas open a little bit, if that does the trick replace the IAC
Old Jun 30, 2011 | 09:07 PM
bkohne1's Avatar
bkohne1
I tried that and it didnt help. I can not hear the fuel pump so i tried to release the pressure on the fuel rail to see if there was any pressure and not even a dribble of gas came out. So im thinking fuel pump went out. What do you guys think?
Old Jun 30, 2011 | 09:15 PM
neilb's Avatar
neilb
Do you have gas in it ?, sorry but you would be suprised ! , check your fuses. Was it running ok on your ride to work ?
Old Jun 30, 2011 | 09:43 PM
bkohne1's Avatar
bkohne1
Yes there is gas in it and i even added more just to be sure the gauge didnt go haywire. Yes it was running just fine on the way to work. I checked the fuses and they looked fine, i also swapped the relays around and still nothing.
Old Jun 30, 2011 | 10:18 PM
neilb's Avatar
neilb
Well like sharps said, check the IAC, dont know that much about it, but this may help, http://www.2carpros.com/articles/how...ol-valve-works
Old Jun 30, 2011 | 10:24 PM
shrpshtr325
THE ULTI-MOD
if you have no fuel pressure, and the fuel pump relay and fuse are good then i would start checking wires, IMO its more likely a wire came loose all of a sudden than the fuel pump going out, but anything is possible, the pump definitely should be audible when you turn the key on.
Old Jun 30, 2011 | 11:40 PM
samnbensdad's Avatar
samnbensdad
I'd try spraying some starting fluid directly into the TB to see if it tries to start. If it does, you have fuel issues. Did you **** anyone off? A buddy of mine that works in retail security had a guy arrested the other day; the very next day he then ended up with a gas tank full of something other than gasoline. Hope this isn't the case...
Old Jul 1, 2011 | 12:42 AM
hydrashocker's Avatar
hydrashocker
Naw you didn't **** us off, besides who cares......LOL
Sounds like a fuel pump. Turn the key to the run position and check the fuel rail port for pressure, if none replace it.
Old Jul 1, 2011 | 08:15 AM
samnbensdad
huh??? I think you misread my post. LOL
