wet carpet
Old Jul 1, 2011 | 08:08 PM
blitzkrieg469's Avatar
blitzkrieg469
Question wet carpet
My carpet in my 03 gets wet where your feet are but only when the ac has been ran. Is there a drain tube that might be clogged or damaged causing this wet problem?
Old Jul 1, 2011 | 10:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yup, the a/c drain tube sticks out through the firewall on the passenger side of the truck (i assume its the passenger side carpet thats wet) and is known to become clogged, an unbent coathanger and some patience should solve the problem
Old Jul 2, 2011 | 12:06 PM
blitzkrieg469
Thankyou
Old Jul 2, 2011 | 12:43 PM
hydrashocker's Avatar
hydrashocker
Here is the drain behind the passenger valve cover on the cab:
Old Jul 2, 2011 | 02:17 PM
topdogcustoms's Avatar
topdogcustoms
03 there's a heat shield over it so its hard to see
Old Jul 3, 2011 | 12:08 PM
blitzkrieg469
Thanks for.all the info
Old Jul 24, 2011 | 08:39 AM
blitzkrieg469
Ok...tried cleaning it out but it didnt help....can i slightly blow air in it to help?.... Or how hard is it to pull the air box out? The water soaks the sponge material at the inside of the fire wall then fills up the floorpan on the passenger side
Old Jul 25, 2011 | 02:33 PM
hydrashocker
It's a real b!tch to remove the air box. Sounds like it's still plugged. You might try a baby nipple brush to push up there. Air shouldn't hurt anything.
Old Sep 24, 2012 | 12:35 PM
otgarzā's Avatar
otgarzā
i just experienced the same thing this month...hopefully getting that drain tube today.
