rear differetial?
Old Jul 4, 2011 | 12:19 PM
topdogcustoms's Avatar
topdogcustoms
You need to pull the diff cover and look around to make sure everything is good
Old Jul 4, 2011 | 12:54 PM
noman's Avatar
noman
I had the cover a few weeks ago to change the diff fluid. Everything looked ok. There was a magnet at the bottom of the diff with a small amount of stuff on it. No pieces of gear. Looked kinda like clutch dust, The stuff you see when changing the trans filter.
Old Jul 4, 2011 | 01:32 PM
topdogcustoms
you could have a after market lsd
Old Jul 4, 2011 | 04:56 PM
noman's Avatar
noman
An after market lsd would that cause the wheels to do what they do?
Old Jul 5, 2011 | 12:50 AM
hydrashocker's Avatar
hydrashocker
It's an open rear end.
The reason it starts to turn open and stops is because the friction thereof isn't enough to sustain critical operation for a LS differential. So the diff move to the open basic build.
Old Jul 5, 2011 | 02:32 AM
topdogcustoms
Hydra your right but he stated there was clutch material in the bottom of the diff
Old Jul 5, 2011 | 04:50 AM
srch4me's Avatar
srch4me
no... he stated that there was metal fillings on the magnet... looked like clutch dust and is clutch dust are two different things... of course there will be some metal filings when you have metal gears meshing together... thats normal wear and tear... doesn't mean he has a limited slip... the likelyhood that someone did put a limited slip in it is slim... they would have told him when he bought it
Old Jul 5, 2011 | 09:11 AM
noman's Avatar
noman
Thanks for your help. I just wanted to make sure there wasn't anything wrong or going bad.
