? about axle gearing
Old Jul 6, 2011 | 09:32 PM
srch4me's Avatar
srch4me
Default ? about axle gearing
so i was lookin at different gear ratios. i have the 3.55 and wanted to upgrade and my question is this... if i put in these 4.10 gears do i have to buy 2 sets, one for the rear axle (9.25) and for the front? or do i just purchase for the rear... and how does that work along with running 4x4?
Old Jul 6, 2011 | 09:37 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you need 2 sets for a 4x4 if you want to do it, so take w/e price you found for one set and double it
Old Jul 6, 2011 | 09:41 PM
srch4me's Avatar
srch4me
damn that puts it up at 550 almost... 0.o
Old Jul 7, 2011 | 07:13 AM
Duranged408's Avatar
Duranged408
And to top that, install labor/gaskets/correct fluid/etc. Its a tough decision when it comes to gearing, but if you plan on owning your D till its dead then it wouldnt hurt to invest in a nice set.
Old Jul 7, 2011 | 12:01 PM
srch4me's Avatar
srch4me
yeah... i plan to drive her till the wheels fall off... then put them back on and drive her some more...
Old Jul 7, 2011 | 12:49 PM
Groggy's Avatar
Groggy
Default A question about your question.
srch4me,
What are your thoughts on the change? I too have the 3.55 gearing in a 4x4 and was considering the change for towing, but I'm not sure what would be better a Superchips or the new gears (assuming of course that I can only afford to do one)
Just curious!
Old Jul 7, 2011 | 04:25 PM
srch4me's Avatar
srch4me
the superchips if i recall correctly and someone can feel free to correct me, tunes your engine to perform better while towing or whatever you tell it to program for... whereas when you upgrade your gearing you actually add more hauling capacity. with the 3.55 you can haul 4300 pounds runing a 5.2. or 5600 with a 5.9 on 3.55 gears... with 3.92 gears on a 5.2 its 5600, and on the 5.9 is about 7200...
Old Jul 7, 2011 | 05:18 PM
shrpshtr325
THE ULTI-MOD
for towing i would do the gears it will cause the engine to rev a bit higher while driving, but will make it easier to move the load
Old Jul 7, 2011 | 09:58 PM
hydrashocker's Avatar
hydrashocker
You will have to get a ring and pinion for both axles, a master install kit, gasket sealant and fluids.
I had mine done by a home town shop for like like $1500 +tax.
Rear:
http://www.ringpinion.com/PartsList....26+Pinion+Sets
http://www.ringpinion.com/PartsList....l+Bearing+Kits
Front:
Old Jul 8, 2011 | 03:23 AM
srch4me's Avatar
srch4me
woah! 371 per set? wow... i like justdifferentials.com... cheeper by almost a hundred bucks...
