00 durango elec issue
Old Jul 16, 2011 | 03:14 AM
low2earth's Avatar
low2earth
Default 00 durango elec issue
i got a 00 durango 4.7 an im having a little trouble with it again. recently i did a motor swap cause other motor blew. well i just finished it up and now when i use my left blinker all my gauges shutoff, and when blinker shuts off all my warning lights will come on. check engine, airbag, washer fluid, etc etc. even my odometer starts to blink then says no bus. an when i turn on my parkin lights my speedo an my tach stop workin. anyone have any idea what would be causing this? no wires where pinched and all sensors would only plug into certain plugs so dont seem like i switched any.
Old Jul 16, 2011 | 08:59 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you definitely have wires crossed somewhere, could be a ground issue but my first thought would be a frayed wire in the cluster area. or a wire for the cluster area, probably power or ground)
when the gauges shut off the dash must be loosing power and then when the blinker comes back on all the lights go on as if you just turned the key on (at least that is how i read your post), this is normal and is just the cluster running a self test.
Old Jul 16, 2011 | 09:19 AM
low2earth's Avatar
low2earth
yea thats exactly what its doing. speedo drops to 0 gas to empty, tach to 0, etc. and then it does act like im turning truck on when blinker off, someone told me it may be the relay. is that possible? an def dint do this before motor swap was done
Old Jul 16, 2011 | 03:25 PM
shrpshtr325
THE ULTI-MOD
you definitely crossed a wire, maybe a relay is in wrong, but i dont see how that would happen, unfortunately (only bc its a PITA) its time to start tracing wires, you have either a bad ground or a short somewhere that is killing the cluster
Old Jul 17, 2011 | 12:14 AM
low2earth's Avatar
low2earth
well tomorrow imma do the rocker or lifter (which ever one is causin my tappin) and then imma put truck on ramps and check all the plugs and everything. cause all we did was disconnect plugs and when done plugged back in. dint take out any relays or nothin like that. i noticed today that there was 1 plug still hangin down an not connected. so really hopin thats the problem.
Old Jul 17, 2011 | 09:43 PM
low2earth's Avatar
low2earth
so after i was chased by a snake today that came from my truck i did some lookin round. this is the onlt plug thats not connected to anything and i cant fig out where it goes. does anyone else have an idea where it might go? best pic i could get with phone. first pic is of plug. second is of rite bout where its located
Attached Thumbnails 00 durango elec issue-tn1.jpg   00 durango elec issue-tn.jpg
Old Jul 17, 2011 | 10:18 PM
shrpshtr325
THE ULTI-MOD
if you dont have an overhead console with temperature readout i would bet that plug goes to nothing on your truck, its in about the correct location (front passenger corner of the engine bay, next to the radiator) and all the trucks were wired for the temp sensor even it if wasnt installed.
Old Jul 18, 2011 | 12:28 AM
low2earth's Avatar
low2earth
damn.... was really hoping that was the problem lol. well ive come to the conclusion that im just gonna pay the 100 bux and take it to dodge. ive been workin on it all day and nothing looks wrong or is frade or anything else. they can also fig out why my motor has a knock. (not rod knock) thought it was a rocker but they seem to be fine. i do have a cell code coming up and my airbag light is on also. so maybe that will be the prob. but cant find the airbag sensor. so ill let them fig it out an ill just fix it myself lol
Old Jul 18, 2011 | 08:47 AM
shrpshtr325
THE ULTI-MOD
the airbag light could be bad clock spring, do you have steeringwheel controls? and if so do they work, does the cruise control work? what about the horn?
Old Jul 18, 2011 | 02:03 PM
low2earth's Avatar
low2earth
yea horn an cruise were workin today on way to dodge
