Incredibly horrible gas mileage
Old Jul 17, 2011 | 01:34 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
there is no way to test the sensors just replace them
and no being sold in oregon does not mean you have the slacker emissions bc im pretty sure my truck has CA emissions on it and it was sold in NJ and hasnt left. you have to check, the sensors will be on the manifold pipes (before the Y) if you have CA emissions, if you dont then it will be between the Y and the Cat, they arent hard to find, just follow the exhaust pipes.
p.s. if Denso brand is OEM rockauto has em for $40 a piece
Old Jul 17, 2011 | 02:01 PM
LuxuryDodge's Avatar
LuxuryDodge
Got the code checked and was for sure, bank one, low, o2 sensor.
That is before cat correct
Old Jul 17, 2011 | 02:33 PM
Old_School's Avatar
Old_School
Actually, there is a way to test if the sensor is sending the proper voltage....
Heres how.... http://www.ehow.com/how_4870344_do-v...en-sensor.html
Old Jul 17, 2011 | 04:39 PM
LuxuryDodge
Whats the best way to get to the plug and the end that actually goes into the pipe? I messed around under the rig attempting to loosen it up with a adjustable wrench (didnt have a large enough crescent wrench) but didnt get anywhere.
Do I need to get one of those custom oxygen sensor sockets and a joint attachment on a ratchet?
Old Jul 17, 2011 | 06:03 PM
shrpshtr325
THE ULTI-MOD
you could get an oxygen sensor ratchet, but i would try a box wrench first, and then a deep well socket if the plug is smaller than the hex flats on the sensor (im not sure how they compare size wise)
Old Jul 17, 2011 | 07:30 PM
hydrashocker's Avatar
hydrashocker
Depends, Bank 1 only refers to the drivers side.
Now there are like 3 different emission set ups so we would actually have the exact code for diagnosing it for you. Anyway Bank 2 is passenger side and the code for instance bank 1 - 1/2 means drivers side pre-cat O2 sensor, and 2/2 means after cat O2 sensor.
Anyway, I went to www.rockauto.com and bought Denso OEM ones which are factory in these and paid like $60 for both of mine and just installed all and was done with it.
Old Jul 17, 2011 | 08:02 PM
shrpshtr325
THE ULTI-MOD
ok let me clarify what hydra said bc he let jack do the typing again, and that causes contradictions.
im only familiar with 2 of the setups, CA and regular (i believe its referred to as 48 state) emissions
CA emissions has 2 banks of sensors 1 and 2,
bank 1 is the drivers side
bank 2 is the passenger side
sensor 1 is precat
sensor 2 is postcat
so sensor 1/1 would be drivers side pre-cat
sensor 1/2 would be drivers side post cat
2/1 passenger side pre cat
2/2 passenger side post cat,
if you only have one bank (48 state emissions) you will only have bank 1 codes, and you will be 1/1 or 1/2 where
1/1 is pre cat and
1/2 is post cat
Old Jul 18, 2011 | 01:31 AM
IndyDurango's Avatar
IndyDurango
Denso is not OEM.
IndyDurango
Old Jul 18, 2011 | 07:51 AM
Bobman's Avatar
Bobman
Pay the extra $$$ and buy the correct ones from the dealer. There are subtle variations between different manufacturers that will affect the performance of the sensor. Also, buy the correct socket to remove the old sensor, it'll save you massive headaches if you break the old one taking it out.
FWIW, my 4.7 (2003) consistently gets 17.5 MPG with most of it being thruway & country roads. My upstream sensor went bad (threw a CEL code as well) and had similar symptoms as yours. A couple other things to check for gas mileage wasters are:
Fan clutch frozen (fan never freewheels).
Poor tire inflation / worn tires.
Bad alignment.
My mileage increased over 1.5 MPG after doing balljoints, new Michelin tires, and a GOOD alignment. I also keep the tires a little hard (38-40 lbs) which may help some.
Bob
Old Jul 18, 2011 | 11:07 AM
98RangoSLT's Avatar
98RangoSLT
Originally Posted by IndyDurango
Denso is not OEM.
IndyDurango
Who is then? I am sure the Mopar packaged O2 sensor has the manufacturer logo on it. Is it possible for you to tell us what yours says? Please?
