P1495 Leak Detection Pump Solenoid Circ
Old Jul 18, 2011 | 02:35 PM
ccexpress's Avatar
ccexpress
Red face P1495 Leak Detection Pump Solenoid Circ
2001 4.7 4x4 AWD
My apologies I know this topic has been discussed many times but I just haven't found the information that I need to fix the problem. Or I probably should say "the way I need it" so I can understand it and fix the problem. This forum has helped many times in fixing things but this one has me stumped.
So far I have changed the gas cap, but after that I am lost as to where to go next, in idiot terms, what would be the next steps, if you could include pictures that would be great, or a map. If there is a DIY with it spelled out please direct me to that post. I did install a K&N cold air intake but have gone over 1000 miles before I got the error code.
Thanks for the help,
Curt
Old Jul 18, 2011 | 02:39 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its not your intake, it could be leaking vacuum lines
https://dodgeforum.com/forum/1st-gen...ml#post2195984
or you can check the connection on the leak detection pump then replace the pump itself ill see if i can get pics of where it is for you this afternoon.
Old Jul 18, 2011 | 02:50 PM
ccexpress's Avatar
ccexpress
I did look at those hoses in the linked post, and they are cracked. I thought that was a different code though p0455? Do you think I could get them from the dealer?
Old Jul 18, 2011 | 04:25 PM
hydrashocker's Avatar
hydrashocker
You can get them from the dealer if you want, but Auto Zone carries a full line of fuel hose for cheap and personally I think they work a lot better.
Old Jul 18, 2011 | 05:37 PM
shrpshtr325
THE ULTI-MOD
+1 hydra, if you want to pay for em from the dealer you can get em, but i just used fuel rated hose and its worked fine
Old Jul 24, 2011 | 08:09 PM
ccexpress's Avatar
ccexpress
Thanks for the help. The light actually went off so I thought it was only the gas cap but poof back on it came, same code. I removed the error memory and it came back on again. I am going to replace the hoses at the canister.
I have a new problem now, I will post it. In short the check guages light came on then my radio went off, then all the electrical went off, (tach, speedomiter, everything) then it died at a stop sign. Had it jumped made it about another 10 miles. Replaced the battery and it started right up all seemed to work but the check guages light still on. Please check out my new post.
Old Jul 25, 2011 | 05:20 PM
ccexpress's Avatar
ccexpress
Back to square one. I replaced the cracked hoses and gas cap. Code will not go away when I disconnect the neg battery cable. What would be my next step and pics would help immensely.
Since the code is Leak Detection Pump Solenoid Circ, where is the solenoid and how do I check it? How can I check the circuit?
Old Jul 25, 2011 | 09:51 PM
hydrashocker
I think the pump under the battery mount.
Old Jul 26, 2011 | 12:24 PM
ccexpress's Avatar
ccexpress
I found the solinoid and one of the two vac hoses was pretty bad. I replace both and checked as many more as I could find under the hood. Looks like all the hoses are now crack free. Can't get the check engine light to go off or erase the code. I followed the instructions on removing codes a couple of times.
Old Jul 26, 2011 | 01:00 PM
shrpshtr325
THE ULTI-MOD
leave the battery disconnected overnight and see if that does it(follow the procedure above, then let it sit overnight)
