Help! Information Center has gone dark...
Old Jul 28, 2011 | 07:19 PM
<3mydurango's Avatar
<3mydurango
Default Help! Information Center has gone dark...
The information center on my 2001 durango blinked a couple of times and then went dark. It doesn't indicate if my seatbelt is off, a door is ajar, etc. Those aren't big deals, but I might need to see my check engine light or something some day. The rest of the instrument cluster appears to be working fine - my brights, blinkers, odometer all work fine. Headlights, interior lights all work fine too. Any ideas and if so, is it something I can do or does it need to go to a shop? Thanks!
Old Jul 28, 2011 | 09:15 PM
hydrashocker's Avatar
hydrashocker
Could be a bad cluster. You could try to reset the cluster. What this is talking about is the trip reset button in the cluster. Hold the button until it starts:
Holding this switch depressed while turning the ignition switch from the
Off position to the On position will initiate the EMIC
self-diagnostic actuator test. The EMIC will automatically
flash the odometer or trip odometer information
on and off if there is a loss of PCI data bus
communication. The VFD will also display various
information used in several diagnostic procedures.
Refer to the appropriate diagnostic information for
additional details on this VFD function.
Both VFD units are diagnosed using
Old Jul 28, 2011 | 10:12 PM
<3mydurango
Default Thanks!
That worked! It flashed and said check and then everything came back on. Thanks so much!!!
Old Jul 28, 2011 | 11:23 PM
hydrashocker
Glad to see it fixed your issue......
