Power steering leak ?
Old Jul 30, 2011 | 02:42 PM
02Rango's Avatar
02Rango
Default Power steering leak ?
First off i read through the many other power steering leak threads. I have a 03 durango R/T 5.9L. Never had any PS issues previuos, yesterday i left my car in a lot in the sun and when i came back it was real low.
I filled it, drove it home, and it seems to be leaking somewhat quickly from the lower line behind the pump. Whats my first move?
Old Jul 30, 2011 | 04:12 PM
hydrashocker's Avatar
hydrashocker
First you need to look at the fittings on the pump and find out if it's the hose leaking or a cracked fitting. In other words you need to wipe off the area and find the EXACT source of the leak. Then we can help you.
Old Jul 30, 2011 | 05:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i agree with hydra, however i did (today of course) find that my power steering return line had actually rusted through and was leaking right at the steering gear (the hard line at that end)
Old Jul 30, 2011 | 06:42 PM
02Rango's Avatar
02Rango
ok so upon further inspection the pump is leaking on the passengers side, which i cannot see or access, not from the fittings. guess i should take it out
Old Jul 31, 2011 | 02:31 PM
hydrashocker
Sharps, if you take it off and have a hose shop near by they can build you another for cheap.
02Rango, I think you nailed it. Remove the pump and get a new one or repair and rebuild. In your year you can use ATF+4 transmission fluid in there for replacement fluid. I would use Valvoline Fully Synthetic ATF+4.
Old Jul 31, 2011 | 06:16 PM
shrpshtr325
THE ULTI-MOD
hydra, the rubber line is fine its the hard line that rusted through, i already ordered the new hoses, should be here tomorrow.
Old Jul 31, 2011 | 11:24 PM
hydrashocker
That's ok, they can build you a new one including the hard line if you want it.
